Hard drive is not showing!
Go to solution Solved by vac,
Thanks to all of you :)
I have just finished putting all pieces together of my computer and I installed OS Windows 7 Ultimate. The installation detected my SSD and the 1 TB hard drive. I chose SSD to install my OS. When the installation finished, only SSD is showing under my Computer window. I booted into setup and I can see I Hard drive and everything. I also check Windows Manager to see hardware and I was surprised to see it there list among GC, SPU and everything.
How can I fix this?
Thanks
P.S. if you want to look at the hardware I have please check out this post: http://linustechtips.com/main/topic/77600-help-build-a-computer/
https://linustechtips.com/topic/79005-hard-drive-is-not-showing/
Go to Disk Management. You'll see it there. Format the drive.
https://linustechtips.com/topic/79005-hard-drive-is-not-showing/#findComment-1084596
