Really struggling and would appreciate some help .
Everytime I boot up my pc it starts fine but then after about a min of being on it shuts down because of high temperatures . I've got a cooker master single fan AIO water cooler on my Fx -8350 . I've tried replacing the thermal paste and  then sometimes it works for a couple of days but then seems to just go back to the same issue ?
Is it something wrong with my Cpu or cooler or how I apply my Thermal paste etc ( btw pc was running fine for like a year and a half before this occurred .
The blue light on my cooler is on when the pc is on ( so don't know if it's possibly a pump issue or not !)
AMD FX-8350 II ASUS R9-20x DCU2 TOP II Fractal Design R4 II Samsung 840 Evo 250gb SSD II Gigabyte 990FXA UD-3 II 8GB Corsair XMS II Cooler Master Seidon 120mm II ACER H236HL Monitor II Corsair K70 II Razer Deathadder II Kinect II
Go check out my Build Log for my "Home Made Gaming POD"
http://linustechtips.com/main/topic/83872-home-made-gaming-pod-build-log/
https://linustechtips.com/topic/789521-cooling-or-cpu-problem/
Yeah, sounds like the pump to me. How long have you had it? I believe most of cooler masters AIO have a 2 year warranty so RMA it.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/789521-cooling-or-cpu-problem/#findComment-9946930
he probably has it longer already. IF you can fit it, the Arctic liquid freezer 120 isnt expensive and can outperform 240mm AIOs as well and its not expensive
https://linustechtips.com/topic/789521-cooling-or-cpu-problem/#findComment-9946939
He didn't mention how long he had had it, just that it had ran fine for like a year and a half... so worth seeing if it's still under warranty for sure. I do agree about the choice of replacement though, unless he can get another 240 cheap, and has good reviews of course.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/789521-cooling-or-cpu-problem/#findComment-9946951
Cheers guys I thought so , it's been over two years , actually had the problem about 7 months ago but I went of travelling for 6 months and just got back so was just trying to sort it out . Okie I'll get a new cooler on the order ! Wanna take it to uni with me so just wanna get it sorted out now rather than leave it last min
https://linustechtips.com/topic/789521-cooling-or-cpu-problem/#findComment-9946997
11 minutes ago, tom_w141 said:
Answers are above I just came to say typo or not "cooker master" is hilarious
? sorry doing this post in my phone , but cheers for the help
https://linustechtips.com/topic/789521-cooling-or-cpu-problem/#findComment-9947002
