Hi all...
so i am getting a pcin a week or so, the issue i have is i can get a i7 7700 with a navida gtx 1080 8gp pascel or i7 770k with a navida gtx 1070, i will play most uptodate games and will be useing it for light rendering and codeing work nothink to heavy ? what would you pick out of the 2 ?
I7 7700K @5.0ghz, Asus Z270-P, Corsair H115i, hyperX 16gb, Asus duel 1070, Nzxt H440
https://uk.pcpartpicker.com/list/ZTsYD8
https://linustechtips.com/topic/789331-help-deciding-on-cpu-and-gpu/
I would go 7700 + 1080. You are not going to overclock it that much.
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
What games are you playing? What monitor do you have?
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
moniter will be a 300-500 moniter, not decided yet, and games are cs:go, battlefeild etc
Seems like two good choices. 7700K and [1070] get my vote. I'd also recommend a 1440 ultrawide if you're able to afford it.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Decide what monitor you're getting first, and then decide on the hardware you get for it. You could easily get an R5 1600 for less money than an i7-7700, get better performance in multi-threaded tasks, and similar performance in games at 1440p and beyond. That way you could get a GTX 1080 and still probably be cheaper than either of the other options.
10 minutes ago, Brett_Bst said:
Hi all...
i7 7700 and 1080 would be my choice
