I have nearly completed my transplant of my rig from a nice metal and glass case to an old beige box (I like the look dont ask me why). Before I didn't have a disk drive but the old case came with one, so I thought I would try and use it even though it was IDE. I got an IDE to SATA adapter and plugged everything in and it spins up but the drive is not registering anywhere, not even in BIOS. Any help would be appreciated. The drive in question is an NEC ND-3540A from 2005.
https://linustechtips.com/topic/789254-using-a-very-old-optical-drive/
if you just want it for the looks how about removing the plastic front cover and fixing it to a newer driver? you get sata and better speeds that way. On a side note, I like those old cases as well :3 pls post a picture :D
Folding stats
Vigilo Confido
It could very well be dead. I've come across a lot of dead drives from various manufacturers from that time period. Or your IDE to SATA interface is bad.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
30 minutes ago, Nicnac said:
"pls post a picture :D "
You asked for this (usb ports have been rigged to be 3.0). And thanks Jamie, I will cobble together the old parts and see if it works for that, good job I didnt throw all that junk out. Could just live without it as I was before so its not a real big issue
Loving it! :D
Folding stats
Vigilo Confido
