My 2nd ever build and it's a Hackintosh...
1. Budget - £600 / $775
2. Aim / Upgrade - building a hackintosh to replace my dying imac. The idea is that the system will be better then the current iMac cheapest iMac specs and be upgradable overtime when money allows.
I shall be using it for web / email / media streaming and my design work. So photoshop, illustrator etc. Also wanting to get into video editing and 3D modeling / printing.
3. Monitors
Plan on running two monitors maybe a 3rd in the future.
4. Peripherals
Keyboard.... Possibly
Montior - Already got one but would like to the same and need a mounting system for them.
Will be using sites such as eBay / amazon / ebuyer.co.uk for my purchasing my parts
Hopefully my build will make sense I've copied and pasted it from a thread on another forum.
So I've not built a pc in a long time!! I think it was 15 years ago since my last build! I built myself a pc as I could make it better spec and for half the price of a mac at the time. Then throughout the years I gradually moved to apple, got myself a G4 power book (which is still going strong!) and an iMac. My reason for this build is i need a new mac due to my iMac being on its last legs and apple is now a rip off! Only good thing about them is the OS and I don't have £1000 spare.
So I'm building a Hackintosh on a budget that will hopefully cost half the price of the basic spec iMac and be alot better!
iMac Spec - www.apple.com/uk
21.5-inch iMac - Item Price: £1,049.00
Hardware;
1.6GHz dual-core Intel Core i5, Turbo Boost up to 2.7GHz
8GB 1867MHz LPDDR3
1TB Serial ATA Drive @ 5400 rpm
Intel HD Graphics 6000
Magic Mouse 2
Magic Keyboard (British) & Users Guide (English)
Accessory Kit
I've been using tonymacx86.com to help with the right configuration of parts to build the hackintosh.
My new Hackintosh Spec (Hopefully)
Gigabyte GA-Z170-HD3P Socket LGA1151 HDMI 7.1 Channel Audio Motherboard £112.12
Intel Core i5 6600 3.3GHz Socket 1151 6MB L3 Cache Retail Boxed Processor £214.98
Gigabyte GTX 750 Ti 4GB GDDR5 Dual-link DVI HDMI PCI-E Grpahics Card £118.20
Corsair Vengeance LPX 8GB (2x4GB) DDR4 DRAM 2133MHz C13 Memory Kit - Red65.97
Samsung 850 EVO 250GB 2.5inch SSD £88.18
Corsair Carbide 300R Case with Window £72.98
Corsair VS Series 550 Watt VS550 Power Supply £38.49
Edimax Gigabit PCIe Network Card £9.68
LG Super Multi Blue Internal 14x Blu-ray Disc Rewriter WH14NS40 £58.22
Total: £778.82
ALL PRICES / PARTS SOURCED FROM EBUYER.COM - this is just a guide for now, parts need changing in places - Im wanting to get the build cost under 600 Including 2 monitors.
Now the under £600 MIGHT BE A CHALLENGE.... BUT I LOVE A CHALLENGE!! And Im not going to get the parts right on first go
instead of a 6600 but maybe a older i7 4790 or a 3770 they will perform a lot better and will be cheaper as well as be better supported by apple due to apple using the same cpus in there 2014 and 2015 macs .
So first place to start is the case - iMac's are nice and shiny but do like custom built pcs
So to save money I dichted the Corseair case and got this http://www.ebuyer.com/725458-avp-mam...reader-cas-748beauty! For £20 delivered.
Now while its not the prettiest of cases it does have a free card reader and window panel plus a free fan and it's got enough room for everything. Only thing is I want some customization and I can always change the case at a later date and it also give me something to do whilst I get the rest of my parts. It's actually in more parts then that now as I wanted to paint it all. I'm going for a grey / pink theme on it.
17953002_1810676335920662_7443887884195218119380_1816472485341047_7908457570366917952677_1810676379253991_87738529009697
So been sketching ideas for my case and this is roughly what it will look likeattachment.php?attachmentid=191120&d=149
It now looks like this. attachment.php?attachmentid=191341&d=149attachment.php?attachmentid=191342&d=149
more to come on the asthetics soon!!
First attempt at wrapping something big but me think its went well :)
Checked out the processor you mentioned it is a possibility but i had thought about going with this spec.....
Case - £20
Gigabyte GA-z170 - £110
Intel i3 Processor 6100 - £110 enough processing power for what i need currently.
GTX 1050 Ti OC / 4GB - £240
Toshiba SSD 120GB - £50
Crucial RAM - 8GB DDR4 2133mhz (could change this too 4GB would save me about £20)
Blue Ray Drive - £50 (Could skip this as it's not essential)
Corsair VS series 550 Watt - £40
That brings me too £528 - If i downgrade too 4GB ram and skip the blue ray, Im saving myself £70 so my total is £450 which leaves me with £150 for monitors and a wifi card, maybe USB 3.0
Should also mention Im rescueing the 1TB out of my iMac as it's only a couple year old and hardly been used.
Any other suggestions to save money where I can?
thats about it for now, part of me wants to make a ryzen build as I loved AMD back when i made my first comp. The processors are fanstic for stuff like photoshop / editing. Might save Ryzen for the next build...
Total: £778.82
- you don't need Z170 for a locked CPU
- get the 6500 instead, it's cheaper and like 200Mhz slower
- get a 1050 or 1050Ti instead and use the Nvidia beta drivers
- good
- good
- good
- bad PSU, get a Corsair CXM instead
idk
