4 minutes ago, Rob21 said:
The thing is my case is in the corner and it blocked on 3 sides. So wouldn't it be better for the back to blow air in, as heat rises up? Mind you the top has 2 fans.
You can try it both ways and record temps, I cannot say what will be best in your application, I would use the rear fan as an exhaust as it is near the cpu.
Yes hot air rises, and you want the exhast by the CPU/VRM to prevent any stagnation of that air.
https://linustechtips.com/topic/788278-case-fan-config/#findComment-9931224
Shouldn't matter much. My case is hanging under table 65mm from wall and there's nothing wrong. What CPU cooler, case and GPU you have? Unless your CPU cooler blows air towards top or is down-draft, rear intake wouldn't do much good.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/788278-case-fan-config/#findComment-9934502
