So I am going to go second year in studies. And need a new rig, something which I can do some mid end-gaming, some video editing, graphics designing and work, mainly essay writing - of course within a reasonable budget of around £500. I was just wondering if this items are compatible with eachother.
This will be the first time I will build a PC, abit nervous but surely it probably will sound like fun - just like building legos. just slightly nervous if this PC doesn't turn on. Suggest any changes I should make if you want. I was thinking of buying a better fan but not sure if it makes a difference
Thanks.
H110m MOBO: https://www.amazon.co.uk/Gigabyte-H110M-S2H-Motherboard-Socket-Express/dp/B01649KMZS/ref=sr_1_fkmr0_1?ie=UTF8&qid=1496454947&sr=8-1-fkmr0&keywords=lga2017+motherboard
i3 7100: https://www.amazon.co.uk/Intel-Core-I3-7100-3-90-GHz/dp/B01NCESRJX/ref=sr_1_1?ie=UTF8&qid=1496455343&sr=8-1&keywords=lga1151+cpu+i3
ZOTAX GTX 1050 TI: https://www.amazon.co.uk/Zotac-GeForce-1050Ti-Mini-Graphics/dp/B01M8M5T4T/ref=sr_1_2?s=computers&ie=UTF8&qid=1496454993&sr=1-2&keywords=gtx+1050ti
Corsair 550w PSU: https://www.amazon.co.uk/Corsair-CP-9020097-UK-PLUS-Power-Supply/dp/B00TE4XSMA/ref=sr_1_1?ie=UTF8&qid=1496455008&sr=8-1&keywords=500w+psu
Mid tower case: https://www.amazon.co.uk/Aerocool-VS-1-Mid-Tower-Case-Window/dp/B0199AQQAY/ref=sr_1_5?s=computers&ie=UTF8&qid=1496455023&sr=1-5&keywords=mid+tower+case
8GB DDR4 RAM: https://www.amazon.co.uk/HyperX-FURY-Memory-Skylake-Compatible-x/dp/B00TY6A1P0/ref=sr_1_1?ie=UTF8&qid=1496455063&sr=8-1&keywords=8gb+ram+ddr4
1TB WB Hard drive: https://www.amazon.co.uk/Blue-Desktop-Hard-Disk-Drive/dp/B013HNYV9W/ref=sr_1_1?s=computers&ie=UTF8&qid=1496454705&sr=1-1&keywords=1tb%2Bhard%2Bdrive&th=1
https://linustechtips.com/topic/788088-building-a-pc-first-time-need-help/
36 minutes ago, anyg said:
Snip
You should be going Ryzen instead for your budget and build intentions: https://uk.pcpartpicker.com/list/KXVbQV
if you have a couple extra dollars you may wish to get a slightly higher quality PSU... but that unit will do a build like yours just fine, and I was trying to keep it as close as possible to the original budget. Whatever you decide to do, good luck.
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  (£149.99 @ Amazon UK)
Motherboard: ASRock - A320M-DGS Micro ATX AM4 Motherboard  (£51.22 @ Alza)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory  (£48.99 @ Amazon UK)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.99 @ Aria PC)
Video Card: Sapphire - Radeon RX 570 4GB PULSE ITX Video Card  (£166.89 @ CCL Computers)
Power Supply: XFX - XT 400W 80+ Bronze Certified ATX Power Supply  (£34.99 @ Overclockers.co.uk)
Other: Dynamode GC7810 (£14.99)
Total: £505.06
Generated by PCPartPicker 2017-06-03 14:27 BST+0100
It costs £500 however shipping add it another £15.
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  (£54.82 @ BT Shop)
Motherboard: MSI - B250M PRO-VD Micro ATX LGA1151 Motherboard  (£60.43 @ Alza)
Memory: Crucial - Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  (£56.72 @ Alza)
Storage: Sandisk - SSD PLUS 120GB 2.5" Solid State Drive  (£48.80 @ Amazon UK)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£41.88 @ Aria PC)
Video Card: Gigabyte - Radeon RX 570 4GB Gaming 4G  Video Card  (£169.99 @ Aria PC)
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case  (£34.98 @ Amazon UK)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£48.36 @ Ebuyer)
Total: £515.98
