:( your PC has run into an issue, we'll restart it for you after collecting some data.
stopcode - PAGE_FAULT_IN_NONPAGED_AREA
This is not the first time this has happened, it happened not even a month ago, but it fixed itself somehow.
When it automatically restarts it just crashes again. Before the blue screen happened spammed with errors that say "The instruction at 0x00000006EDFC00 referenced memory at 0x00000004EDF5C00. The memory could not be writted. Click OK to terminate the program" and the box is WerFault.exe - Application error
I tried wiping both my SSD and HDD and reinstalled windows, that didn't fix it. I took out each drive indivisually to see if it was a hdd or ssd problem, and reinstalled windows again. that didn't fix it. I also ran memtest through windows on each stick indivisually and they both passed with 0 errors.
I talked to a microsoft support rep and they tried having be boot to lgkc and it said critical process died with a blue screen then we tried to use recovery mode and it blue screen crashed again. I tried reinstalling windows and after it installed it restarted and gave me a blue screen again. I've tried swapping around the RAM in different slots and when I removed a single stick it actually let me into the OS for the first time but after 10 minutes of me screwing around on my desktop it blue screen crashed again.
The windows rep said that my OS stick could be corrupted so I installed a windows10 version that he gave me onto a flash drive and it still gave me a blue screen with the same error code after installed. I ran CHKDSK through the CMD and it came up with errors on my HDD but it fixed them after a scan and I still get a BSOD.
I feel so hopeless. I think I've tried everything. I don't know what to do please help me.
my specs are here:
I7 6700k 4.00 GHZz
Corsair VENGENCE 8gb x2
Asus STRIX gtx 1080 8gb
Asus PRIME z270-k
EVGA SuperNova 750W G2
Cooler Master 212 evo
256gb 850 evo
2TB WD Black HDD
Masterbox case 5
Windows 10
https://linustechtips.com/topic/787650-bsod-help/
How much RAM you got?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/787650-bsod-help/#findComment-9923770
Also try not to have the text a darker colour because some people might not be able to read it on the dark theme
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/787650-bsod-help/#findComment-9923783
Just now, Dankcube said:
So sorry, I'm new to this forum I don't know how to do that
Oh ok I was telling you try not to use dark colours and I don't even know how to change the colour on the font and I've been here for almost 2 months
https://linustechtips.com/topic/787650-bsod-help/#findComment-9923803
