Laptop buying help
Solved by Jurrunio,
4 hours ago, Viharlovag said:Can you recommend a good cooler for that price you mentioned for the ASUS ROG Strix GL553VW FY147D then?
Buy a cooler IF you need to. That is test it's stock cooling capabilities before consider whether you need one. What if what others say are false and the cooling is actually nice?
If you need one, it's better to search "best laptop cooler 2017" sth like that so you get the most up-to-date info.
