Mainly gaming some triple A titles at high-medium settings.
Willing to get 60+ frames.
Smooth experience.
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($62.49 @ SuperBiiz)
Motherboard: MSI - B250M PRO-VD Micro ATX LGA1151 Motherboard  ($62.88 @ OutletPC)
Memory: Crucial - Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($59.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: Gigabyte - Radeon RX 570 4GB Gaming 4G  Video Card  ($178.99 @ SuperBiiz)
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case  ($38.85 @ OutletPC)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply  ($44.90 @ Jet)
Total: $496.54
Generated by PCPartPicker 2017-06-01 13:07 EDT-0400
https://linustechtips.com/topic/787494-500-system-worth-it/
Motherboard: ASRock - B250M-HDV Micro ATX LGA1151 Motherboard  ($61.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-2133 Memory  ($54.88 @ OutletPC)
Video Card: MSI - Radeon RX 580 4GB ARMOR OC Video Card  ($204.99 @ SuperBiiz)
Case: Fractal Design - Core 1100 MicroATX Mini Tower Case  ($28.99 @ SuperBiiz)
Total: $506.67
Generated by PCPartPicker 2017-06-01 13:15 EDT-0400
A little more expensive but it has a 580. @nitsuga5124 If you don't get a quality PSU now, you could be facing dead components in the future.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/787494-500-system-worth-it/#findComment-9921803
4 minutes ago, nitsuga5124 said:
RAM: 2133mhz
PSU: 450W is enough and cheaper
GPU: go for the RX580 if you have enough with what you tacked from the RAM and PSU
Keep the RAM at 2400, as the g4560 as proven benefits from 2400MHZ making it equal an i3 7100.
I wouldn't go cheaper than a 40$ power supply. This is a good quality unit and less wattage is not worth the compromise.
choosing a cheaper case is enough to get an RX580, but they're all out of stock.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/787494-500-system-worth-it/#findComment-9921811
Smooth experience.
-snip-
yeah.. this just happened
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($158.99 @ SuperBiiz)
Motherboard: ASRock - A320M-DGS Micro ATX AM4 Motherboard  ($54.99 @ SuperBiiz)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory  ($49.88 @ Newegg)
Storage: Western Digital - AV-GP 320GB 3.5" 5400RPM Internal Hard Drive  ($18.99 @ Amazon)
Video Card: Sapphire - Radeon RX 570 4GB PULSE ITX Video Card  ($169.99 @ SuperBiiz)
Case: Rosewill - SRM-01 MicroATX Mini Tower Case  ($19.99 @ Jet)
Power Supply: EVGA - 500W 80+ Bronze Certified ATX Power Supply  ($36.99 @ SuperBiiz)
Total: $509.82
Generated by PCPartPicker 2017-06-01 13:20 EDT-0400
https://linustechtips.com/topic/787494-500-system-worth-it/#findComment-9921836
