Fan Controller or Motherboard
Solved by VIVO-US,
It comes down to personal preference. If your motherboard has fan control, then you can use the board's software to set and automatically control the speed. With the fan control on the case, all you do is press the button on the case to switch between low and high speed.
kisserik93 ·
Posted in Peripherals4 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory11 -
6
popularlion ·
Posted in Troubleshooting5 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1
