2 hours ago, EnderCat said:
Ok so which of these are better? Cooler Master T2 Vs DEEPCOOL GAMMAXX 300 also this is the motherboard so would there be any Clarence issues or anything??
As for acoustic performance, as well as fan quality (Using a Hydro Bearing over a Sleeve Bearing), I do believe that the DeepCool GAMMAXX 300 dominates superior. It also features more heatpipes with aids to it being your best choice.
As well as such, both appear to provide equal 'cooling' performance across both coolers with each having an 130 TDP.
Though take note it is not apparent whether DeepCool actually supply thermal compound with that CPU cooler, but Cooler Master has a slim pouch of it included already.
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/787189-cpu-cooler-versus/#findComment-9918773
I watched a review and strangely enough they do include thermal paste, Not in a tube or bag but pre applyed
https://linustechtips.com/topic/787189-cpu-cooler-versus/#findComment-9918859
Oh, well everything is good to go then! :D I mustn't have spotted that in the images.
https://linustechtips.com/topic/787189-cpu-cooler-versus/#findComment-9918862
11 hours ago, EnderCat said:
wait a sec I am looking at the qna part and half the people say it comes with thermal paste and half says it doesn't
Thermal Paste is not particularly expensive these days, you'd probably find a bundle for a pound or so more wth you specific cooler anyway on the likes of Amazon.
Always good to have backup thermal compound for future re installations of such is what you ever desire to do c:
https://linustechtips.com/topic/787189-cpu-cooler-versus/#findComment-9920569
