Hi, I was just wondering if you had any suggestions for laptops around 1000$ (up to 1300$) that had dedicated graphics (1050Ti and above), a 7700HQ or up, and 16G of RAM. I would prefer a 15.6" 4K screen, but I haven't really found anything in that range.
https://linustechtips.com/topic/786979-laptop-help/
PC Specs:Custom Built PC
CPU:AMD Ryzen 3 1200 GPU:Zotac GeForce GTX 1050 TI Mini RAM:Corsair Vengence 2400 MHz DDR4 Motherboard:ASUS Prime B350M-A AM4 Motherboard Case:Corsair 100R PSU:Corsair VS450
Laptop Specs:Acer TravelMate 8472
CPU:Intel Core i5 560M Memory:2GB DDR3 CPU:Intel HD Graphics Case:Its a Laptop Motherboard:Laptop Motherboard
https://linustechtips.com/topic/786979-laptop-help/#findComment-9915843
Was looking as the same laptop as @iPC listed,seems a excellent choice but it has a 1080P screen (15.6 inch) and a laptop at that price range definately won't have a 4K display and and a powerful enough GPU at that price range,if your budget was $1400-1600,then a MSI Gaming Laptop would meet your needs with a 1060 tho (probably still not powerful enough) and the above ASUS skylake laptop,even worse even though it is a 960M and a i7 6700HQ,definately (or maybe partially able to play on that hardware,less demanding games like CS:GO,etc)
https://linustechtips.com/topic/786979-laptop-help/#findComment-9915889
Moved to laptops section.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/786979-laptop-help/#findComment-9916348
Thanks! Might skip the 4K screen and have the Pascal chips. Wondering what you thought of the HP OMEN. My friend is thinking of getting one with a 4K screen for around 1200$ and upgrading RAM and SSD for another 90 or so.
https://linustechtips.com/topic/786979-laptop-help/#findComment-9918026
HP Omens are shitty, IMO, terrible build quality, keyboard, screen, thermals, and battery life.  If you want a budget gaming laptop, have a look at the Dell Inspiron 7567.  They're actually on sale right now, I believe.
https://linustechtips.com/topic/786979-laptop-help/#findComment-9918053
Thanks for the input.
https://linustechtips.com/topic/786979-laptop-help/#findComment-9918056
No 4k, but everything else is solid. Specced properly comes to around $1200.
https://www.gentechpc.com/product-p/sager-np7850.htm
You can easily replace the screen with a 4k Sharp one if you want 4k that much.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/786979-laptop-help/#findComment-9918577
Thanks! Do you know what battery life is like?
https://linustechtips.com/topic/786979-laptop-help/#findComment-9919062
Just know that this specific laptop uses Clevo's N850xx chassis. That means you can look up reviews for the Gigabyte Sabre 15 as it uses the same chassis. So.
3.5-4 hours. Decidedly underwhelming.
If you realistically plan on getting it, let us know, we can spec it properly. alot of pitfalls in laptop speccing.
Laptop Main
https://linustechtips.com/topic/786979-laptop-help/#findComment-9919115
True. Thank you!
https://linustechtips.com/topic/786979-laptop-help/#findComment-9919131
Just now, iPC said:
True. Thank you!
With the 1060 in this chassis, it absolute requires liquid metal to function properly. only gentech at the moment offers it. if you get it at another retailer, you will experience extreme high temps and throttling.
Laptop Main
https://linustechtips.com/topic/786979-laptop-help/#findComment-9919136
30 minutes ago, iPC said:
Would this laptop be ok for school as well as gaming?
its fine. most gaming laptops are just as good for school. downside is shit battery life.
24 minutes ago, iPC said:
Also, sorry if this is a stupid question, but can I just use my desktop copy of windows for OS?
yes. IF it's a legit consumer copy you can install it on different machines. BUT it needs to be uninstalled on the desktop.
but why bother, you can get windows for cheap from places like Kinguin, Windowsstoreswap on reddit, win7 upgrade to win 10 (still works fyi).
Laptop Main
https://linustechtips.com/topic/786979-laptop-help/#findComment-9919248
Should I just have them clean install windows?
https://linustechtips.com/topic/786979-laptop-help/#findComment-9921905
15 minutes ago, iPC said:
Would that work?
no. alienware graphics amp only works with alienware laptops because its a proprietary connector.
secondly a razer blade stealth is garbage.
Laptop Main
https://linustechtips.com/topic/786979-laptop-help/#findComment-9928689
11 hours ago, iPC said:
would you suggest that kind of route? or no.
eGPU? no.
not with your budget.
Laptop Main
https://linustechtips.com/topic/786979-laptop-help/#findComment-9930371
