Hello I would like to build my first pic that would be able to run the following games smoothly at 60 fPs in 4kwithout drops  , borderlands series , csgo , witcher 3 , minecraft ( heavily modded ) , ark survival , however i dont know which graphics card to chose to do so , I would like to keep the price as low as possible
https://linustechtips.com/topic/786921-help-choosing-first-pc/
we need a set budget, not as low as possible.
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915229
For 4K 60Fps you would need at least a GTX1080.
PC: Case: Cooler Master CM690 II - PSU: Cooler Master G650M - RAM: Transcend 4x 8Gb DDR3 1333Mhz - MoBo: Gigabyte Z87x-D3H - CPU: i5 4670K @ 4.5Ghz - GPU: MSI GTX1060 ARMOR OC - Hard disks: 4x 500Gb Seagate enterprise in RAID 0 - SSD: Crucial M4 128Gb
Phone: Samsung Galaxy S6
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915234
Just now, nxt4n said:
For the pic without monitor I would like to try keep it below 1300-1400 British pounds
need any os/peripherals? you already have a monitor?
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915236
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£198.94 @ CCL Computers)
CPU Cooler: CRYORIG - H5 Universal 65.0 CFM CPU Cooler  (£34.99 @ Overclockers.co.uk)
Motherboard: MSI - X370 SLI PLUS ATX AM4 Motherboard  (£132.80 @ Alza)
Memory: Kingston - Savage 16GB (2 x 8GB) DDR4-3000 Memory  (£115.95 @ BT Shop)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  (£73.88 @ Ebuyer)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.99 @ Aria PC)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G  Video Card  (£641.90 @ Alza)
Case: Phanteks - ECLIPSE P400 ATX Mid Tower Case  (£59.99 @ Novatech)
Power Supply: BitFenix - Whisper M 850W 80+ Gold Certified Fully-Modular ATX Power Supply  (£89.99 @ Overclockers.co.uk)
Total: £1386.43
Generated by PCPartPicker 2017-05-31 10:54 BST+0100
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915245
Total: £1386.43
What's the good thing about BitFenix PSU? Just curious
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915248
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  (£275.94 @ Aria PC)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  (£77.38 @ Amazon UK)
Memory: ADATA - XPG Z1 16GB (4 x 4GB) DDR4-2800 Memory  (£89.92 @ Amazon UK)
Case: Thermaltake - Versa H23  ATX Mid Tower Case  (£26.48 @ Aria PC)
Power Supply: be quiet! - Pure Power 10 CM 500W 80+ Silver Certified Semi-Modular ATX Power Supply  (£63.98 @ Ebuyer)
Total: £1287.47
Generated by PCPartPicker 2017-05-31 10:57 BST+0100
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915249
Total: £1386.43
Is a dog ryzen good though ? Will my upgrade ability be as good as let's say an i5 or i7 Katy lake?
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915250
not in stock.
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915252
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915255
the ryzen 5 1600 is good enough, you can upgrade to a ryzen 7 in the future(not needed for gaming) and AMD plans to support am4 till 2020 while lga 1151 still has 1 cycle before it gets changed IIRC.
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915264
Ok that's good to hear , what monitor would you recommend to go with this build
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915266
if you got the money, something like this:
https://uk.pcpartpicker.com/product/H3mxFT/aoc-ag241qg-238-165hz-monitor-ag241qg
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915268
LG 24GM77
My head on 2019 :
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915271
Also , wouldn't the 1500 x be better as it has higher speed ?
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915272
the 1600 has 2 extra cores, and you can overclock it to 4ghz if you want.
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915274
I'm looking for 4K not 1080p
LG 27UD58-P Click here
My head on 2019 :
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915280
Just now, p.klokgieter said:
3.9ghz* hehe
Don't forget 3x more threads as the i5-6600K
My head on 2019 :
https://linustechtips.com/topic/786921-help-choosing-first-pc/#findComment-9915281
