I got watchdogs 2 on release but I haven't really been able to play it much with school and then getting a job after graduating, but I tried to play it a few days ago and it would freeze really hard and I got a notification that I needed to add more ram. I thought 8gb was more than enough for games because I've never had this problem before. I'll buy more if needed, but if it's something else then I'd rather fix it.
https://linustechtips.com/topic/786559-are-8gb-not-enough/
Well I closed all the applications on my computer and ran the task manager where I could monitor it and it didn't seen to change anything. Just showed it maxed out. I have a new graphics card and monitor on the way so I'll just order some more ram and see if that solves the problem. Thank you guys.
https://linustechtips.com/topic/786559-are-8gb-not-enough/#findComment-9910758
5 minutes ago, Tedster said:
Nothing is ever enough. I often struggle with my 32GB of RAM!
What are you doing with your PC so 32GB isn't enough? VMs?
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/786559-are-8gb-not-enough/#findComment-9910777
Just keep usage by other things down and you'll probably be fine.
Are you opening too many tabs? I even being commanded by my phone to clear ram that has 4 background applications running and 8 tabs open in max of 20 (I don't want to go over that)
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/786559-are-8gb-not-enough/#findComment-9911248
It's:
- Heavy chrometab addiction
- Refusal to close down things if I'm going to be using them in the next couple days
- Having minecraft modpacks sometimes eat 6GB or 8GB, and wanting to leave them open in the background while running another ram-heavy game
- Running virtual machines every now and then
- Occasionally faffing around with ramdisks
- Occasional memory leaks in things I run
Sig under construction.
https://linustechtips.com/topic/786559-are-8gb-not-enough/#findComment-9911350
I agree.  I play games on my main PC and don't max above 12GB in some of the harshest settings.  My Plex server doesn't hit anywhere above 16GB when transcoding for even a dozen streams.  And the only time I come close to that amount is on my work machine when I'm doing my coding, using Adobe AE, and similar applications
https://linustechtips.com/topic/786559-are-8gb-not-enough/#findComment-9911561
