I want to get a new system so then I can play games and record and make some videos a lot more better (I using a i3 5020u and it's complete crap and it's a huge bottle neck for the iGPU) and I really can only spend about $500 Canadian and I have the GPU, PSU, HDD, Case so I would need everything that isn't listed above
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/786378-need-build-fast/
what gpu, psu, case?
this should work with most cases https://ca.pcpartpicker.com/list/7GhFM8
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908344
GTX 770, EVGA 450 BV, Zalman Z1 Neo
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908358
the small mobo may look odd in the case so if you want a full atx mobo https://ca.pcpartpicker.com/product/yBtWGX/asrock-ab350-pro4-atx-am4-motherboard-ab350-pro4
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908366
the psu isn't very good, get a better one.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($280.25 @ shopRBC)
Motherboard: ASRock - AB350M-HDV Micro ATX AM4 Motherboard  ($84.50 @ Vuugo)
Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4-2133 Memory  ($111.99 @ Amazon Canada)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.98 @ NCIX)
Total: $521.72
Generated by PCPartPicker 2017-05-29 23:38 EDT-0400
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908375
Total: $521.72
The PSU I have is completely fine and I don't need to get another power supply because it's using money that I could use in different areas
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908391
Don't cheap on PSU
The EVGA BV isn't a good quality PSU
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908402
the BV is not good in terms of quality and it only claims to provide the full 450w at 30 degrees celsius. that's a tempreature that can be easily hit and your 770 eats a good lot of power under load, the BV won't be able to power it for long.
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908403
4 minutes ago, ZM Fong said:
Don't cheap on PSU
Well I have the psu on hand and I don't want to spend unesseary money in places
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908425
can you return the unit or sell it?
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908436
My dad knows that I have it and he is willing to pay for part of my build so all I need is the Mobo+CPU+ram that's it so I'm sticking with the psu for now but th first upgrade is the psu then the GPU
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908443
alright, fine. just remember to replace it soon.
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908449
I know it's not the best but it was a decent psu from a decent brand because I didn't want to get bug spray as my psu
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908453
EVGA doesn't make their own power supplies, they outsource it from other manufacturers. the BV is made from HEC and is made with cheap chinese components. not fine for something like a gtx 770.
https://linustechtips.com/topic/786378-need-build-fast/#findComment-9908457
