Advice about my next PC
Go to solution Solved by TheDane,
1 minute ago, TheDane said:
First of don't get any of those monitors they have horrible colours and viewing angles.
But this PC should be great now and even better in the future, because more cores will mean more in games soon.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($218.58 @ OutletPC)
CPU Cooler: be quiet! - Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($65.49 @ SuperBiiz)
Motherboard: Gigabyte - GA-AB350M-Gaming 3 Micro ATX AM4 Motherboard  ($88.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($126.89 @ OutletPC)
Video Card: Zotac - GeForce GTX 1070 8GB Mini Video Card  ($334.99 @ Amazon)
Case: BitFenix - Nova ATX Mid Tower Case  ($52.36 @ Amazon)
Power Supply: EVGA - SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.89 @ OutletPC)
Total: $962.18
Generated by PCPartPicker 2017-05-29 15:11 EDT-0400
As for a monitor, i always recommend the Samsung C24FG70 as it has the best panel possible with a high refresh rate of 144Hz at only 280$. This will leave you with about 200$ for everything else, such as a keyboard and a great pair of headphones :).
2
I am about to buy a new pc ( that i think is a rly good one) and i was hoping that maybe some advices would help me get a better one! my badget is 1500$ (keyboard,headphones included)
The pc i will buy is 1500$ with the keyboard and mouce on the price...  just so you know :)
https://linustechtips.com/topic/786170-advice-about-my-next-pc/
@GirvanaWantsBinnieBalls
This is pretty good for your money
Motherboard: ASRock - X370 Taichi ATX AM4 Motherboard  ($193.98 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($126.99 @ Amazon)
Storage: SK hynix - SL308 120GB 2.5" Solid State Drive  ($57.89 @ OutletPC)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($44.99 @ Amazon)
Video Card: Zotac - GeForce GTX 1080 Ti 11GB AMP Edition Video Card  ($699.00 @ B&H)
Case: Phanteks - ECLIPSE P400 ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ Newegg)
Total: $1491.41
Generated by PCPartPicker 2017-05-29 14:58 EDT-0400
I don't include peripherals as they can range vastly, you can get a combo for $10 im sure.
https://linustechtips.com/topic/786170-advice-about-my-next-pc/#findComment-9906154
Total: $1491.41
A 10$ combo isn't even worth 10$.... Keyboard and mouse are just as important for once experience as the specs of the PC, it is after all what connects you to it
https://linustechtips.com/topic/786170-advice-about-my-next-pc/#findComment-9906169
22 minutes ago, Blackhole890 said:
for what? usd, aud..?
Just as @Blackhole890 said we need to know what it will be used for before we can find something worth your money. Is it for gaming only or is it for 3D-rendering and workstation purposes? Also what resolution do you want to play at? 1080p, 1440p or 4k?? Ultrawide or non-ultrawide?
https://linustechtips.com/topic/786170-advice-about-my-next-pc/#findComment-9906178
Gaming, and ill be streaming and making videos. my screen will prob be Acer GN246HL or this asus vg245h
now... i allready have a mouse, im talking about headphones and keyboard
https://linustechtips.com/topic/786170-advice-about-my-next-pc/#findComment-9906211
Total: $962.18
As for a monitor, i always recommend the Samsung C24FG70 as it has the best panel possible with a high refresh rate at only 280$. This will leave you with about 200$ for everything else, such as a keyboard and a great pair of headphones :).
https://linustechtips.com/topic/786170-advice-about-my-next-pc/#findComment-9906243
Total: $962.18
2
https://linustechtips.com/topic/786170-advice-about-my-next-pc/#findComment-9906253
Total: $962.18
1 hour ago, GirvanaWantsBinnieBalls said:
thank you so much!
well, that psu is pretty poor and it can be improved... I suggest going what @tom_w141 suggested, better psu, gpu, (and an overkill motheboard) or this one, with 500gb ultra fast ssd... If you can't afford, change psu to seasonic s12ii 620w
PCPartPicker part list: https://pcpartpicker.com/list/rND3QV
Price breakdown by merchant: https://pcpartpicker.com/list/rND3QV/by_merchant/
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($84.49 @ SuperBiiz)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  ($179.00 @ B&H)
Total: $1503.03
Generated by PCPartPicker 2017-05-29 16:56 EDT-0400
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/786170-advice-about-my-next-pc/#findComment-9906780
Total: $1503.03
Good overall but be careful when choosing the cheapest of the cheap motherboards. MSI use lesser quality components, it wont overclock as well as other boards either, lastly MSI were having Ryzen BIOS issues so I never recommend MSI for Ryzen.
https://linustechtips.com/topic/786170-advice-about-my-next-pc/#findComment-9906839
Total: $962.18
NEX is an awful PSU
https://linustechtips.com/topic/786170-advice-about-my-next-pc/#findComment-9906840
17 hours ago, tom_w141 said:
NEX is an awful PSU
Shoot, Sorry I had forgotten to correct it in the list, I meant to put the G3 not the NEX.
@GirvanaWantsBinnieBalls Here is the right list!
Video Card: Zotac - GeForce GTX 1070 8GB Mini Video Card  ($349.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($88.88 @ OutletPC)
Total: $991.17
Generated by PCPartPicker 2017-05-30 11:03 EDT-0400
https://linustechtips.com/topic/786170-advice-about-my-next-pc/#findComment-9910619
