Hello, I'm trying to build my first pc, and I wanted to make sure all these parts worked together. I don't have any previous parts I can use to flash bios or anything, so I wanted to make sure these would work out of the box. Also, can I use the 960 Evo m.2 ssd as a boot drive? It wasn't on the list of supported drives. Similarly, the ram was not on the list of supported ram for the motherboard. Will it still work?
https://pcpartpicker.com/user/Samfrog/saved/CVVK8d
^Build^
https://linustechtips.com/topic/785411-will-this-build-work/
-power supply is way overkill
-get a non founders edition 1080 ti
-960 evo doesn't improve boot times or app launch times, it's a waste of money. Just get a 1tb 850 evo instead.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9898242
Pretty solid setup man, I pretty much have the same setup except I have the 6700k. And too your ssd question, yes you can have the 960 as the boot drive, I have mine as a boot drive. The hero board is a extremely nice board, the ssd will work perfectly fine. Just when you start the PC up, make sure the 960 is priority over the other ssds/hdds.
Edit: If you wanted to save some cash, I'd tune the motherboard down, that specific one is made to OC like there is no tomorrow. But still a solid board.
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9898249
 Also forgot to mention, do you even have the wifi to make use of the 4x4 of that Asus wifi adapter? It's really expensive and probably not useful for you...
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9898252
3 minutes ago, Linksys120n said:
Ah you see the problem you have there is that your still buying intel now that ryzen is out... give the red team a try will yah?
If they're only gaming Ryzen isn't worth it.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9898254
Is there a motherboard yall suggest? I do want a lot of pcie lanes for expandability.
The insane amount of fans is cause I'm paranoid about cooling. First time doing this and that's one of my main concerns.
Why not Founders edition 1080ti?
I recognize the psu is overkill, but it's better to overkill vs underkill right? Also I want room for perhaps an sli in the future.
Also I just like Intel, don't want to use ryzen (although ryzen is pretty cool)
PC is for gaming and *some* video editing, mostly gaming
Edit: Also will not explicitly supported ram work?
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9898285
I was half joking about the ryzen thing I tried to show it in the tone of how I typed it.... also the founders edition cards get really super hot and make a ton of noise... after market coolers are dead silent when not gaming.
derp
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9898319
Unless you are doing heavy OC don't bother with a high end board. It's a waste of money. All boards have the same amount of pcie lanes (16, 2x8 for SLI), as lanes are supplied by the processor.
Parts are good enough to cool themselves.
FE is loud and mediocre. Good for water-cooling, but other designs from OEMs like the EVGA iCX and MSI Gaming models are better.
850w would be enough for that system total, even with SLI
Go for Intel here - best gaming performance now.
idk
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9898325
Founders is loud and not, not worth it.
You only really need 850w even if you go sli. 1000w overkill over overkill.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9898340
Which one would you recommend instead of founders? Preferably not over $750 and one that won't get too hot
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9898354
If you want rgb, the aorus is pretty decent. If you want a lot of control over fans (you can control fans individually) and/or want to be able to monitor vrm, mosfet, and vram temperatures the evga sc2 is a good option. If you feel like going to the top of the $750 the Asus Strix is probably one of the best when it comes to temps and noise out of all the air cooled 1080 tis. Note though that once you get into semi decent 1080 ti territory they all overclock pretty much the same, so getting something like the strix over the aorus won't give you much of a performance jump, it'll just run a bit cooler and maybe quieter.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9899917
Because the the cards with aftermarket coolers usually run quieter and cooler. And some will cone factory overclocked.
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9900072
^Build^
What monitor are you going to be using ?
https://linustechtips.com/topic/785411-will-this-build-work/#findComment-9900188
