I have a usb headset (hyperx cloud 2), and a crappy old pair of beige speakers that I got for free from work (single 3.5mm jack)
I only need to use one at a time and I'd like to switch between them fully, using simple software without unplugging anything.
I tried using a program called AudioSwitch, it's nice and easy to use, but it only moves some programs, and others seem to be locked to either my headset or my speakers.
Any ideas? Something with hotkeys would be fantastic. Thanks!
R5 1600, Asus Prime B350, 16gb corsair vengeance, nzxt s340, gigabyte gtx 1060, cryorig h7, 256gb adata su800. More in Link.
https://pcpartpicker.com/list/RC4KQV
https://linustechtips.com/topic/785352-audio-help/
just use the windows sound device manager?!
EDIT: Right click on the little speaker in the taskbar then select standard sound device accordingly.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/785352-audio-help/#findComment-9897677
that takes too long, and I can't set hotkeys to easily change it. I'd like to just press like (ctrl + PgDn) to switch inputs, and need a program for that.
https://linustechtips.com/topic/785352-audio-help/#findComment-9897681
hey, found a cool program in case anyone else wanted it, its called AudioSwitcher, https://audioswit.ch/er . It works very well and let's me easily map my own binds, I've had no problems and definitely recommend for anyone who sometimes wants to game and sometimes wants to listen to music.
https://linustechtips.com/topic/785352-audio-help/#findComment-9897731
