Difference between basically same GPUs
Solved by MVPernula,
Hey there!
When it comes to the same GPU's like RX 580 vs. RX 580 it mostly comes down to size and looks.
They're mostly the same, some beating other slightly in temps and overclockability.
But those even varies between the brands - Some Gigabytes are better than other Gigabytes.
So basically pick the one that looks best in your opinion ![]()
Ultimately you wont feel a difference.
Some are factory overclocked if you don't like doing it yourself though ![]()
