3 minutes ago, nerdslayer1 said:
purpose?
I was just about to say
I'm thinking of 4K minecraft and hopefully 4K Overwatch max settings at 60fps
because I have a 4k 60hz monitor
asus pb287q to be exact
I also want to be able to record, edit, and use blender
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9878524
2
ryzen 1700 with a 1080 or 100ti would be better, @deXxterlab97 can make a good build for you.
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9878555
if you can spare another $20 look at this, psu is much better and a much better cooler and a ryzen 1600.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($217.89 @ OutletPC)
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler  ($87.89 @ OutletPC)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  ($107.89 @ OutletPC)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($126.94 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.33 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB G1 Gaming Video Card  ($498.68 @ Amazon)
Case: Rosewill - RISE Glow ATX Full Tower Case  ($64.99 @ Amazon)
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.89 @ OutletPC)
Optical Drive: Samsung - SH-224DB/BEBE DVD/CD Writer  ($21.49 @ OutletPC)
Wireless Network Adapter: TP-Link - TL-WN722N USB 2.0 802.11b/g/n Wi-Fi Adapter  ($12.89 @ OutletPC)
Case Fan: Corsair - CO-9050015-BLED 52.2 CFM  120mm Fan  ($10.93 @ OutletPC)
Case Fan: Corsair - CO-9050017-BLED 66.4 CFM  140mm Fan  ($14.49 @ OutletPC)
Case Fan: Corsair - CO-9050016-BLED 52.2 CFM  120mm Fans  ($18.79 @ OutletPC)
Speakers: Logitech - S120 2.3W 2ch Speakers  ($11.99 @ SuperBiiz)
Other: Logitech HD Pro Webcam C920, Widescreen Video Calling and Recording, 1080p Camera, Desktop or Laptop Webcam  ($61.99 @ Amazon)
Total: $1419.05
Generated by PCPartPicker 2017-05-23 16:10 EDT-0400
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9878578
Total: $1419.05
my question is why ryzen over 6700k there are a ton of people who say 6700k is awesome and it has 4 cores
and i kind of need a liquid cooler because I'm looking to overclock
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9878617
You don't need  a liquid cooler to overclock, that air cooler is miles better than a corsair h50, and the 6700k is a good cpu but the Ryzen 5 1600 has two extra cores and has a much better upgradable path.
they wouldn't make air coolers for the fun of it, they're for overclocking also.
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9879278
is it quiet the one u picked?
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9879282
Deffo, noctua are known for making some of the best fans on the market, they're not the best looking but far better than any corsair make. The cooler also has no moving parts i.e. Pump, so the cooler cannot fail, only the fans.
if you don't like the look of it, the best alternative is to get a cryorig r1 ultimate.
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9879294
I'm not going for looks dude. But seriously it is 84 dollars. And you still ahven't answered my question. Is it quiet?
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9879299
That corsair h50 is honestly a pile of steaming sh*t and if you think for one minute you will get better overclocks on that compared to a dual tower air cooler you're sorely mistaken. I've been building pcs since 2012 and although it's not a long time, I know my stuff.
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9879316
18 hours ago, CyberFerno said:
do y'all think this does the job
https://pcpartpicker.com/list/7pdPd6
https://pcpartpicker.com/list/TLDHZ8
I tweaked your build a tad to give you a slightly
better overclock. As well as some other changes.
That case has pre installed 120mm fans with blue LEDs in the front, as well as a 140mm exuast in the rear. I'd wait to see if you're displeased with their preformence before replacing them.
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9882018
dude awesome
what about fans for the liquid cooler what will I do about it
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9882217
i tweaked your idea for me just a bit
is this good enough still
keep in mind im looking for 4k overwatch 60fps max settings
https://pcpartpicker.com/list/Yvqnhq
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9882267
dude awesome
It comes with two fans in the box.
and do z170m boards support overclock and have an easy BIOS
Most definitely. The z170 chipset is want you want for overclocking, hence the change I made.
As for 4k on overwatch, for the most part you'll be able to run it fine at 60-70fps on ultra. You WILL experience dips below 60fps. don't expect not to.
and are these fans enough to cool my gpu
Yes, three 120mm fans for intake with three 140mm for exhaust will cool just fine. You'll get better temps than I do in my case. My GPU (GTX 1080 Armor, 2.1ghz OC) usually runs at 81c on games like Overwatch. I run Overwatch on Ultra at 144fps locked for the most part. On a 144hz 1440p monitor.
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9882829
DUDE 81 C THAT'S DANGEROUS
https://linustechtips.com/topic/783728-first-pc-build/#findComment-9883049
