Adobe Premiere Pro - Help
Solved by Evanair,
You're viewing V2. Try scrolling down to V1. Bar should be on the right.
If you can't fix it that way, just reset your workspace and that'll fix it too.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases2 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
10
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
