Right now i have Corsair 88R case, but I want to buy sharkoon c10 (https://www.sharkoon.com/product//16426#desc) because it is much smaller, but on their site it says The case is not compactible with Modular power supplies. Why? I have an semi modular cx500m, is that noncompactible too? I have put all my pc parts in the link down below, can you guys help me figure out if there is any incompactibilities before i buy it. For example will my corsair h75 fit in there, in my understanding it will but can you check? Will my gtx 1070 strix fit in there? I also have corsair sp 120 performance editions, can I use those? So if you know answers to those questions or to some others let me know. Also the PCPARTPICKER is flagging my power supply as non fitting, but it should fit?? The max lenght of a power supply for Sharkoon c10 is 150 and cx500m is 140mm, so it should fit.
https://de.pcpartpicker.com/list/wMrsr7
IT IS CLOSED NOW; I CANT BUY A NEW CASE ANY TIME SOON; BUT 88R ISNT THAT BIG.
https://linustechtips.com/topic/783618-need-help-with-a-new-case/
problem might be that the case is blocking the middle section of the psu where the modular cables plug in
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
1 minute ago, Almostbauws said:
I just found this image online: IS the cs750m similar in size as cx500m?152473.bca87d179809cbcdffa1e95f9fc1743f.
yeah probably
- Ryzen Build -
2x Dell UP2516D
According to the website, ATX power supplies should fit. If you got the FAQ section, it says it in there.  As for your graphics card, as long as its less than 31.5cm in length, it'll fit just fine it seems. The cooler might be an issue.  looks like there is plenty of room for the rad and fan, but the tubing might not fit.
