What settings should i make for an ssd and hdd storage system?
3 minutes ago, Vandorlot said:I have A LOT OF QUESTIONS. Sorry,
If I decide on going with an hdd and ssd combo for my new PC
1) What settings will I have to change.
2) If I install windows on the SSD, will it make that the boot drive.
3) Does having programs on the same drive that the OS is on cause booting the OS to be slow.
4) Can I install all programs onto the HDD, even if they dont have an option on where to install.
5) Can I move the directories programs files and Program file X84 to the HDD.
6) Anything else I should know?
1 - for standard SATA SSD and SATA HDD there shouldnt be any. If NVMe SSD there might be.
2 - Yes. Recommendation: unplug the HDD until after base windows fully installed.
3 - No.
4 - If they dont provide option, you need to be careful about how you get them on to HDD, but usually, yes.
5 - No, you cannot "just move" them.
6 - There is no real reason to move Program Files or the x64 version. Let all the microsoft stuff stay there. Just choose install location for programs (games etc) that you add.
