I want to overvolt my r9 270 and msi afterburner is not unlocking it.
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/782275-unlock-msi-voltage-control/
https://gyazo.com/773d5d15b8e3bc20b14cf23907e47f16
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
4 minutes ago, Stevoisboss said:
Build
You can't change voltage then. It happened to me on an XFX 270X DD.
any other bios or software.
Build
I guess you could flash a custom bios but any other gpu overclocking software will give you the same problem.
ok
Build
