So I need to find the intercept between a straight line (y=14.5) and a cosine curve. I have attempted the eqn but unfortunately without success. I've attached an image of my working out below so please correct if you notice anything off with my algebra.
Thanks in advance
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/781781-math-help/
11 hours ago, Dash Lambda said:
You made an error when multiplying by 621.
How do i fix it?
Desktop
LAPTOP
https://linustechtips.com/topic/781781-math-help/#findComment-9859205
7 minutes ago, Dash Lambda said:
Look at your work.
I'll give you a hint: You have multiple terms.
Oh right so I need to multiply the whole entire left side by 621 instead of just (22/69 *pi).
But now my answer is 160.......and I know it should be around 4-5 or somewhere in the single digits.
Desktop
LAPTOP
https://linustechtips.com/topic/781781-math-help/#findComment-9859252
If you corrected it properly, it should read: x = 621(cos-1(29/171) + 22π/69)/(100π)
Which evaluates to a reasonable value.
"Do as I say, not as I do."
-Because you actually care if it makes sense.
https://linustechtips.com/topic/781781-math-help/#findComment-9859284
Yes, I corrected it to that but when I enter it into my calculator with all the correct bracket placements, it always gives the result of 160, regardless of what I do. I'm wondering if my calculator is unable to handle these forms of equations....because I tried an online calculator which gave the seemingly correct result of approx. 4.7.
https://www.symbolab.com/solver/algebra-calculator/\frac{621\left(\arccos\left(\frac{29}{171}\right)%2B\frac{22\pi}{69}\right)}{100\pi}%3Dx
Desktop
LAPTOP
https://linustechtips.com/topic/781781-math-help/#findComment-9859332
What calculator do you have?
https://linustechtips.com/topic/781781-math-help/#findComment-9859341
Just the basic Casio fx-100 AU plus. I will be pretty triggered if the calculator is causing issues.
Desktop
LAPTOP
https://linustechtips.com/topic/781781-math-help/#findComment-9859348
1 minute ago, Dash Lambda said:
Your calculator is set to degrees.
What should it be set to?
Desktop
LAPTOP
https://linustechtips.com/topic/781781-math-help/#findComment-9859418
Radians.
Radians are the fundamental measure of angle that actually works, degrees are just a modification that makes it easier to say.
https://linustechtips.com/topic/781781-math-help/#findComment-9859473
Radians.
Oh! Thanks heaps!! You're a life saver.
Desktop
LAPTOP
https://linustechtips.com/topic/781781-math-help/#findComment-9859474
