Might be a corrupted OS. Unlucky that your PC was in the middle of modifying important OS files while it was unplugged. (essentially, you "bricked" your OS)
just reinstalling windows would be the easiest way to fix it, but you can also run windows' built-in recovery tools to try to fix it. (there's a thing you can put onto a USB stick and boot off of which tries to repair your windows install.)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/781619-help-with-startup/#findComment-9854749
