I am planning on building a computer later this year and i have finished the list of all the parts i am going to purchase but i need help with the psu. i read the thing at the top of the forum and it did not really help me. i just need to know what brands are good, what wattage i need etc..
parts that i am getting will be in the spoiler (if i forgot to put something just ask xD
Monitor: Dell S2417DG G-Sync (3 of them)
MotherBoard: Asrock Z270 SuperCarrier 1151
CPU: Intel i7-7700 kabylake lga 1151
Case/Chassis: Phanteks Luxe tempered glass edition
GPU: Asus Nvidia gtx 1080ti strix
Heatsink: Dark rock pro 3
RAM: Trident Z RGB 32gb 3466mhz
Optical drive: blu-ray Pioneer bdr-209dbk-kit
Fans: Masterfan pro rgb 120mm (6 fans, some maybe 140mm) getting these when they are released.
thank you so much
https://linustechtips.com/topic/781455-help-with-psu-please/
  Reveal hidden contents
thank you so much
Thought I helped you with this before...?
Anyways, that "list" I posted is useful if you know where to start and with an i7 and 1080 Ti system you'd want to start at at least tier 2. Look for something capable of 550W or higher, 850W or so if you want to SLI down the road. The EVGA GQ/G2/G3, Corsair RMx/RMi, Seasonic X-series, etc are a good place to start.
https://linustechtips.com/topic/781455-help-with-psu-please/#findComment-9852389
3x 128GB Samsung PM961 M.2 (2x Kryom PCI-E M.2 by Aqua Computer) on windows os raid and 1x PM961 as os Host on the motherboard m.2 slot
+ 250GB Samsung 850 EVO
+ 7200RPM Seagate 1 Terabyte HDD
  • PSU
    seasonic 750 prime platinum Active PFC F3
  • Cooling
    Noctua NH-D15S (original fan replaced by an Noctua 140mm industrialPPC-2000 IP67 PWM + Steel 140mm fan guard)
  • Keyboard
    Cherry MX Board 6.0 ISOANSI + Vector/Tai keycaps+ Landing pads + O-rings
  • Mouse
    BenQ Zowie EC2-A White Edition
  • Sound
    Edirol Roland UA-25EX + Beyerdynamic DT 770 Pro
  • Operating System
    Windows 10 x64 (Enterprise) SP1, OpenSUSE, Remnux
https://linustechtips.com/topic/781455-help-with-psu-please/#findComment-9852404
17 minutes ago, NrKj105 said:
Yeah, no.
thank you so much
https://pcpartpicker.com/product/kz7CmG/evga-power-supply-210gq0650
https://linustechtips.com/topic/781455-help-with-psu-please/#findComment-9852481
you did help me before but i have changed some parts plus i wanted help again because i had forgotten what u said. i will look at all the suggestions you have just mentioned and try to re read the post pinned to the top. sorry for reposting lol.
https://linustechtips.com/topic/781455-help-with-psu-please/#findComment-9852537
what about an evga 850 g3?
https://linustechtips.com/topic/781455-help-with-psu-please/#findComment-9852961
All you do is go to the PSU Tier list (Click on the cases and PSU's tab and then it is the first one). Any thing from tier 1 is golden. With this build I'd say go for 650 watts or more. If you want SLI, like STRMfrmXMN said go with at least 850 watts. Hope this helps
https://linustechtips.com/topic/781455-help-with-psu-please/#findComment-9853065
i hope to do sli in the future so i will get the 850, however it will not be sli when i first build it
https://linustechtips.com/topic/781455-help-with-psu-please/#findComment-9853136
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/781455-help-with-psu-please/#findComment-9854212
9 hours ago, NrKj105 said:
No?
If you want to SLI 1080 Tis then get the 850G3, sure.
https://linustechtips.com/topic/781455-help-with-psu-please/#findComment-9854766
