Soo this is my first build ( I haven't built it yet ) and I want to know your opinions on it and if I have to change something. I will mostly play games on it and maybe stream or record some stuff. The price is around ~1000,00$ (CAD).
https://ca.pcpartpicker.com/list/bVywnn
Thank you for the help !
https://linustechtips.com/topic/781135-my-first-build/
Z170/270 motherboard are meant for overclocking. You selected the i5 6500, which isn't overclockable. Only Intel's "K" CPUs can be overclocked (ie. 6600k). Either drop the motherboard down to a B150/B250 or choose a "K" cpu that can be overclocked. It's a waste of money otherwise. Also, you don't need an aftermarket cooler unless you're doing a decent overclock, so drop that if you aren't.
You really should get an SSD in addition to your mechanical storage drive; a 240GB would do nicely. It's amazing. Trust me. With adjustments as stated above, you should be able to fit one in.
Don't bother with the GTX 1060 3GB.  Either get a 6GB 1060 or get a 4GB or 8GB RX580. I highly recommend the 580, it's a better value for your money. The 4GB rx580 should be around the same price or bump it up to the 8gb rx580 for just a little more cash.
Alternatively with the motherboard/CPU situation, you could and should consider Ryzen 5. You should have no problems fitting a Ryzen 5 1600 into the budget, plus it can be overclocked on it's lower end B350 motherboards and comes with a pretty good stock cooler. The extra cores and threads help a ton with pretty much everything else you'll be doing or could be doing besides gaming and it's gaming performance is roughly on par with i5s. It's good future-proofing.
Here is an example and my personal recommendation for a just over $1000 CAD build using Ryzen 5:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($280.25 @ shopRBC)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($126.00 @ Vuugo)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($87.99 @ Amazon Canada)
Storage: PNY - CS2211 240GB 2.5" Solid State Drive  ($109.99 @ Amazon Canada)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($85.95 @ Vuugo)
Video Card: MSI - Radeon RX 580 8GB ARMOR OC Video Card  ($316.99 @ Amazon Canada)
Case: Corsair - 100R ATX Mid Tower Case  ($54.99 @ Newegg Canada)
Power Supply: SeaSonic - S12II 620W 80+ Bronze Certified ATX Power Supply  ($74.99 @ Newegg Canada)
Total: $1137.15
Generated by PCPartPicker 2017-05-17 18:51 EDT-0400
The case can be changed to anything around the $50 mark, there is plenty to choose from.
Desktop - CPU: Ryzen 7 3700x | COOLER: be quiet! Dark Rock 3 | MOBO: ASRock X370 Killer SLI/ac | RAM: 32GB Corsair Vengeance LPX 3200MHz | GPU: MSI RTX 2070 Super Gaming X Trio | STORAGE: 2x XPG SX8200 Pro 1TB, Crucial MX300 525gb, Seagate Barracuda Pro 4TB | CASE: Phanteks P400s TG White | PSU: Corsair HX750i
Laptop - Dell XPS 13 | Intel i7 7500u | Intel HD 620 Graphics | 8GB RAM | 256GB M.2 SSD
Peripherals - KEYBOARD: KBD67 Lite w/Gateron Milky Yellow Pros | MOUSE: Razer Deathadder V2 | AUDIO: Sennheiser HD 6XX, Truthear Hexa | MONITOR: Dual 1440p 27" MSI Optix MAG274QRF-QD
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848233
Total: $1137.15
ARMOR OC is ugly AF
S12II is really old, group regulated.
PCPartPicker part list: https://ca.pcpartpicker.com/list/k2hk3F
Price breakdown by merchant: https://ca.pcpartpicker.com/list/k2hk3F/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($299.99 @ Memory Express)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($129.99 @ Memory Express)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($89.98 @ DirectCanada)
Video Card: Gigabyte - Radeon RX 580 8GB AORUS 8G Video Card  ($339.99 @ Memory Express)
Case: Corsair - 100R ATX Mid Tower Case  ($64.99 @ NCIX)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.98 @ DirectCanada)
Total: $1187.90
Generated by PCPartPicker 2017-05-17 18:55 EDT-0400
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848243
8 minutes ago, JDE said:
ARMOR OC is ugly AF
Total: $1187.90
The ARMOR OC is a good deal in Canada, has a decent cooler, and it's made by a reputable brand. If looks matter that much, than he can go ahead and get whatever. The standard AORUS seems to be a good card on paper, but I haven't heard too much about it. Personally, I don't think it looks that bad. The M12II, although old, still is a quality PSU. I don't claim to be any PSU expert though, that's for sure. CXM is an excellent choice, but I would consider bumping it up to a 550W. A 450W is cutting it somewhat close and it isn't fun needing to buy a new power supply when you realise it isn't enough for your upgrade. Power supplies are expensive here.
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848267
Just now, Shadow6767 said:
The ARMOR OC is a good deal in Canada, has a decent cooler, and it's made by a reputable brand. If looks matter that much, than he can go ahead and get whatever. The standard AORUS seems to be a good card on paper, but I haven't heard to much about it. Personally, I don't think it looks that bad. The M12II, although old, still is a quality PSU. I don't claim to be any PSU expert though, that's for sure. CXM is an excellent choice, but I would consider bumping it up to a 550W. It isn't fun needing to buy a new power supply when you realise it isn't enough for your upgrade. Power supplies are expensive here.
1. I know, I live in Canada, read my location.
AORUS is like STRIX but made by GIGABYTE, its their flagship series.
2. CXM is better and slightly cheaper (550W vs 520W)
3. I live in Canada, again read my location.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848279
Yeah I know. I never stated once that you didn't live in Canada. And my PSU was a 620W and the one you suggested was a 450W. Where are you getting "550W vs 520W" from?
Just trying to help the owner of the thread out here.
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848287
CXM550 vs M12II 520W
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848292
PCPartPicker part list: https://ca.pcpartpicker.com/list/fB8rsJ
Price breakdown by merchant: https://ca.pcpartpicker.com/list/fB8rsJ/by_merchant/
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor  ($246.25 @ shopRBC)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($64.99 @ Amazon Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($66.25 @ Vuugo)
Case: Corsair - 270R ATX Mid Tower Case  ($69.99 @ NCIX)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($79.98 @ DirectCanada)
Total: $1058.44
Generated by PCPartPicker 2017-05-17 19:09 EDT-0400
I know the 1600 has a little more performance but idk seems fine to me.
lttstore.com
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848299
My most sincere apologies sir, but I have no clue what you are tying to get at. I thought we were talking about the 620W S12II VS the CXM 450W?
Also, the Aorus XTR is Gigabyte's flagship, not the regular Aorus.
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848301
The CX450M is $65 and is semi modular
The CX550M is $75 and is semi modular
The M12II 520 usually is ~$80 and is fully modular.
You sacrifice some performance and wattage for that full modular goodness.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848311
The S12II 620 is $75 (which is the one I choose), the M12II 520 is $80 the CX550M is $80. I think we've gotten into a hardcore debate over $5. Probably best we just leave it at any of the three options will work just fine, but I wouldn't get anything short of 500W.
Sorry to the thread owner for probably ending up reading all this.
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848329
Its not modular.
I'm sad.
It was torture.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848333
Just now, Kewaninou said:
I've made some changes in the build and here is a new version
Also, I'm not very familiar with the AMD CPU, is there any difference between the AMD and Intel CPU ?
https://ca.pcpartpicker.com/list/6Hh3nn
Thanks everyone for your help !
Well there are some differences.
Not much though, but its better for future proofing.
Stay away from all 1060 models now that 580 is out
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848540
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2800 Memory  ($74.99 @ Newegg Canada)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.50 @ Vuugo)
Video Card: Sapphire - Radeon RX 580 4GB PULSE Video Card  ($279.99 @ Newegg Canada)
Case: Cooler Master - MasterBox 5 (White) ATX Mid Tower Case  ($69.50 @ Vuugo)
Power Supply: EVGA - BQ 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($89.99 @ Newegg Canada)
Total: $1045.21
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/781135-my-first-build/#findComment-9848628
