you thought amd had huge power consumption
Guest
http://forum.overclock3d.net/showthread.php?t=58253
rasmus66 from overcloock3d's fourm has done a volt mod on his gtx 8800 by soldering two "epower boards" to his pcb
and i thought only amd could reach such insane levels of power
just waiting for his overclocks and benchmarks now
I... what? I mean... what? How... why... I don't...
Blackout - Intel Core i5-4670K | Xigmatek Dark Knight II Nighthawk Ed. | Gigabyte GeForce GTX 770 (2GB) | 8GB Corsair Vengeance Mem. | Gigabyte GA-Z87X-D3H Mobo | 250GB Samsung 840 Series SSD | 1TB WD Black HDD | Seasonic Platinum SS-660XP2 660w PSU
I hope he's going to use LN2
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
What a waste of money and resources, i doubt he will get much of a benefit if any at all, he even ahs to create drivers or use hacked ones.
Listen if you care.
it's an overclocker community ... they buy even gtx titan just to stress it and learn about.
well it seems that he has to use LN because there is no room for an ordinary cooler and yes this will be AWESOME
only 6X6pin pcie? thats not enough to get it over 2ghz. he'll needs 8X8pins for that  :P
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
