1 minute ago, Linksys120n said:
it really is that simple... they only fit one way and they just kinda plug right in and click when you've done it right.
yep it looks like ddr3 socket you just buy 2 sticks of ddr3 and put them in and hope dell didn't do any dickery
https://linustechtips.com/topic/779888-i-need-help/#findComment-9832918
Okay, take the ram out carefully and find the speed and type.  That is how you will order you next two.  Thing is, I can 't tell you if it will even support more.  We need some kind of information.  What version of windows and if it is 32 or 64 bit would be a huge help.  Also the current size of each module it already has would help as well.
https://linustechtips.com/topic/779888-i-need-help/#findComment-9832943
speed doesn't matter this isn't ddr2 and you can tell by the slot its ddr3 and yeah it supports more can't you see the 4 slots
https://linustechtips.com/topic/779888-i-need-help/#findComment-9833134
Yeah, thanks for the lesson super sleuth.  I've seen a lot.  I have worked on a lot.  I have a process.  I like to be 100% sure and 100% accurate when I give someone my opinion.  Your answer "you just add 2 rams to it into the open slots" sounded more like a troll than an actual answer.  So I am completely blown away by the fact that you could tell it was DDR3.  What you don't know is, I've seen refurbs shipped with 4gb ram 2 per slot with 32bit windows 7 on them even.  I've seen people downgrade operating systems many many many times.  You just never know.  And I don't want to be that asshole that made a guy waste $40.  Granted Amazon has a pretty nice return policy, it's just nice to be right the first time.
https://linustechtips.com/topic/779888-i-need-help/#findComment-9833351
So here is my final answer.  If you have a 64 bit version of windows.  and both of those sticks of ram add up to 4gb or more, then you will gain absolutely nothing from adding more ram, but you can.  Adding 4gb will set you back around $40-50.  You will however see a HUGE improvement in performance, if you replace your hard drive with an SSD($90) and a small improvement by adding a $30 graphics card.  Provided you are up to the challenge.
https://linustechtips.com/topic/779888-i-need-help/#findComment-9833404
dude.... depending on what he's doing more ram will help alot upgrading to a ssd will also help but so will more ram especially if he runs a lot of programs
https://linustechtips.com/topic/779888-i-need-help/#findComment-9835822
Open up every program you have, not including games, and check to see how much memory you use.  Mine it 3.6gb.  And that includes an ETH mining program that is cooking on two GPUs.  And a virus scan.
https://linustechtips.com/topic/779888-i-need-help/#findComment-9836733
18.2 gigs and that isn't everything just my normal set up. also eth miners don't use up computer ram they use up gpu ram................ just because its cooking your gpus doesn't mean it would be using your ram
https://linustechtips.com/topic/779888-i-need-help/#findComment-9838560
It uses both, but not as much system memory or it would take 4 to 8gb.  However it does use more than any other individual program I run outside of gaming.  Couldn't imagine using 12 to 24gb for the big miners.  Those things were expensive enough.  You know how much a 1600watt PSU costs?!   I'm just grateful the ETH prices came back up.
https://linustechtips.com/topic/779888-i-need-help/#findComment-9839124
