Hey all,
I'll get straight into the action, I'm planning to build myself a new computer, as my old computer is just not sufficient enough for the games I want to play. My current pc has the following specs:
Amd Athlon X4 740
AMD Radeon R7 260X
And some other generic parts, as I bought it pre-built from a local company 5 years ago.
The budget I'm aiming for is 800 euro's max, which comes down to 700 dollars, I find. The main use of the computer will be gaming, but I'm also planning on going to college, so it has to have smooth productivity aswell. I already own 2 monitors and peripherals, so those don't concern me. both monitors being just regular full HD.
I put together a list of components, but as it is my first time building a pc myself, I'm afraid I'll screw up and have incompatible parts and that something will not work. Here are my preferred parts:
AMD Ryzen 5 1400
ASRock A320M
Crucial DDR4-2133 2x4 GB
Crucial MX300 525GB SSD
MSI Radeon RX570 ARMOR 4G OC
Corsair Carbide 88R
Corsair CX450M
Arctic F12 120mm
I'm looking for any and all tips you guys can give me, thanks in advance.
EDIT: Here is the PcPartPicker link: https://pcpartpicker.com/list/fjCf4C
EDIT: After some tinkering and playing around with the tips you guys gave me, I came up with the following setup:
AMD Ryzen 5 1400
ASRock AB350M
G.Skill Ripjaws V Series 2800MHz 2x4GB
WD Green SSD M.2 240 MB
WD Blue 1TB
AUS ROG-STRIX RX 570 O4G
Corsair Carbide 88R
be quiet! Pure Power 10 500W
Arctic F12 120mm Case fan
https://pcpartpicker.com/list/PfBf4C
Any tips?
https://linustechtips.com/topic/779828-first-ever-pc-build-will-it-work/
5 hours ago, TheNickqq said:
Why did you go for better memory and another Motherboard, if I may ask?
Ryzen benefit from high speed RAM
The mobo you choose can't overclock
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
5 hours ago, 1kv said:
Please don't recommend 7350K, it's a shit CPU, Ryzen 5 or even an i5 is much better
Desktop specs:
-snip-
May I know why you need such large SSD instead of going 1TB HDD + 240-275GB SSD?
Also, if RX 480/580 is a bit more, go for it.
Desktop specs:
Hey all,
Amd Athlon X4 740
AMD Radeon R7 260X
AMD Ryzen 5 1400
ASRock A320M
Corsair Carbide 88R
Corsair CX450M
Arctic F12 120mm
I would go for faster ram as ryzen needs it becuase ryzen is 2 core clusters and I would go with a 1600 if you can the extra 2 cores could do a lot and If possible get a b or x mobo as it will have the ability to oc the cpu. Also get a better rated psu maybe? I heard that cheaping out on psu's can hurt your system from power surges. I mean it's not a bad psu just if you could I would try to get a little bit higher tier psu
https://pcpartpicker.com/list/MdBsf8
If you can aforid this. Would probably get 5 or so years out of It again and some oc on the cpu.
My current computer only has an hdd and it makes a hell of a lot of noise constantly, i wanted to go as silent as possible because i find the sound very annoying. Maybe you know what type of hdd makes the least noise? It would be a great way to lower the cost and maybe allow me to go for the 580 instead. :)
Usually HDD don't make loud noise unless there's a problem with HDD
Desktop specs:
4 minutes ago, TheNickqq said:
I think there might be a problem with my hdd then :( When it's not idle, it makes noise like just as loud as my typing on my keyboard :|
Yeah probably there's a problem. Try changing a new HDD
Desktop specs:
I still need a new pc though, my old one is getting to slow for modern games, but I think I will go for an HDD with an additional smaller SSD then, do you have any recomendations concerning the hard drives?
Any HDD will work just fine, WD Blue and Seagate Bararcuda are among the popular choices
Desktop specs:
Right, I will go do some research, thanks mate :)
Welcome:)
Desktop specs:
Sorry about recommending the 7350K, only reason why I recommended it is purely because it's a bit more than a 7320 but can overclock and doesn't bottleneck too many video cards.
I would definitely go for either an i5-7500 or Ryzen 5 1400. I would go for an RX 470 or 480 since the RX 5 series is literally a rebranded version of the 4 series that AMD are selling for a higher price.
You are nearly at twice his budget. Also for $1300 that isn't a good build.
