So essentially I'm waiting to buy my gpu because I'm broke I'm saving for a 780 but I get my last 2 parts today. I have a quick question about the IGpu, since I do want to use my computer can it be over clocked at all? I won't play bf4 on it mobviously but how far can it be pushed. I'll list my build for you.
-Asus hero vi
-i7 4770k
-hyper x 240gbssd
-be quiet dark rock pro 2
-crosair rm850
-hyper x 16gb ddr3 1600mhz
-soon to be gtx780 later to be sli.
https://linustechtips.com/topic/77975-igpu-help/
It can be overclocked but it's generally not worth the trouble doing so as gains are quite small.
https://linustechtips.com/topic/77975-igpu-help/#findComment-1070331
You know will people post these type of specs it pissing me off asking if they can't over clock with a freaking 850w
He's talking about oc'ing the iGPU.
https://linustechtips.com/topic/77975-igpu-help/#findComment-1070332
What is stopping you from overclocking ???
FX 6300 @ 4.2 Gigahurtz 1.325V ,  ASRock 970 Extreme 4 mobo  ,  Kingston Hyperx Blu 2X4GB @1600Mhz  , Asus GTX 960 DCU ii Black OC  , Hyper 212 Evo , Samsung 850 Evo 250 GB , WD 1 TB caviar Green , Xonar DG sound card , Seasonic M12ii Evo 620W PSU , Corsair 200R case ,4 random case fans.
https://linustechtips.com/topic/77975-igpu-help/#findComment-1070340
Yes it can be done, but you will not see much improvement from it. The iGPU is not meant to game, and it already has far more than enough power to power just about anything else (Leaving out folding, Bonic, rendering, or 4K work) you would ever want to do.
Just use your iGPU at stock settings until you get your nvidia cards.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
https://linustechtips.com/topic/77975-igpu-help/#findComment-1070361
What kind of games other than league since a potato can play it could I expect the gpu to run properly while I wait
Dota 2, and any Valve Engine Games (ie. Gary's Mod, HL2, etc)
It can play hardcore videogames like Crysis (It can run BF4, but you would have to have it on all low and 720p, or 768)
I'm the Forum Owl
*Who*
https://linustechtips.com/topic/77975-igpu-help/#findComment-1070379
My friends trying to make me try I belive it's called path of exile supposedly like Diablo think on low I could handle it or should I just stick to my laptop while I wait to play games
You can play it.......even with the iGPU
I'm the Forum Owl
*Who*
https://linustechtips.com/topic/77975-igpu-help/#findComment-1070395
