Fans??
Go to solution Solved by sahi,
Noctua NF-F12
what case do you have? are you using it as an intake? Radiator? Heatsink? Exhaust?
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/77967-fans/#findComment-1070204
if you can afford get noctua's
if you dont want to spend that much go corsair sp series
https://linustechtips.com/topic/77967-fans/#findComment-1070207
^Along with this
Where are you shopping/located? Budget? Any color scheme?
https://linustechtips.com/topic/77967-fans/#findComment-1070211
Noctua NF-F12
CPU: i7-4770k @stock  GPU: Gigabyte Windforce GTX 780ti OC  MotherBoard: Gigabyte GA-Z87X-UD4H  RAM: Corsair Vengeance Pro (1600 MHz, 2x8GB)
CPU Cooler: Stock Cooler  Storage: Samsung 840 Pro 2x256gb(OS/Games), 1TB Seagate Barracuda(storage)  PSU: Corsair AX860i
Case: Corsair Obsidian 750D Mouse: Roccat Kone XTD Keyboard: Corsair Vengeance K70
https://linustechtips.com/topic/77967-fans/#findComment-1070213
NB Eloops
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/77967-fans/#findComment-1070220
These are a nice alternative to Noctua
%99.9 of the performance, %200 of the looks
https://linustechtips.com/topic/77967-fans/#findComment-1070237
