Hey Guys
I´m currently building a new PC but I dont really know how to set up my Airflow correctly.......
Is there something I should be aware of or some General Tricks?
So I made 2 diffrent drafts wich one of them is better and  incase both are crap what is the best way to set it up?
1:
Airflow1
2:
Airflow2
Thx for your help :D
(sry for the bad made Pics ;))
https://linustechtips.com/topic/77958-best-setup-for-airflow/
Picture 1, but leave it how it is.
Front to back airflow is always good, IMO.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/77958-best-setup-for-airflow/#findComment-1070040
Hey Guys
1:
2:
Picture 2, BUT flip the top left intake to an output fan.
Nope
the first one because positive air pressure
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/77958-best-setup-for-airflow/#findComment-1070042
Nope
Positive air pressure is good in a case where you want the output of air to be passive (all intakes), usually better for smaller cases.  In a larger case, you just want the air moving and having that rear fan as an intake, especially that top fan as intake as you suggested, will create a much more turbulent airflow.  Then main goal of airflow for a gaming focused build is to get hot air away from the GPU as quickly as possible so the only air it pulls through the cooler is cold air.
https://linustechtips.com/topic/77958-best-setup-for-airflow/#findComment-1070295
More fans does not mean better air flow.
What you want is:
- air coming in the front, and hot air coming out
- Get appropriate fans for case and heasink/radiator. They are not the same fans, for an optimized setup
- Large 120mm fans is plenty, and great size for cooling, and quietness.
- For high heat systems, or high overclock over air, get 2 fans for the front. One at the bottom for providing fresh air to the GPU and other cards, and the other for the CPU. The long GPU will act as a split.
So in your case, Option 1 is the best, if you reverse the direction of the top fans to out.
https://linustechtips.com/topic/77958-best-setup-for-airflow/#findComment-1072953
What you want is:
Second looks better. Hot air goes up...
I probably go for the first one....
Thx for all the help :D
https://linustechtips.com/topic/77958-best-setup-for-airflow/#findComment-1073897
