Will be cooling an AMD FX-6100 OC to 4.1GHz @ 1.375V, load temps are between 48 and 50 degrees C.
Upgrading soon to an FX-8320 and overclocking it so will it be enough for this?
Also there is the 412S and the 612S close in price something like £10 between the 212 and 612 so would it be worth going for one of the other ones?
Cheers guys
Nothing Is True, Everything Is Permitted
(Do not try to work the meaning out you will go insane I have tried it)
https://linustechtips.com/topic/77923-cooler-master-hyper-212-evo/
I hear the 612 is pretty bad for the price so I would either stick to the Evo or look into even better things like the Be quiet! Dark rock series or anything noctua.
"If you do not take your failures seriously you will continue to fail"
It's the prices on the Dark Rock and the Noctua coolers... The UK prices are mad right now and I don't have that much to get a new cooler :(
I use a 212 EVO on my 8320 @4.2GHz
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
if you can, get a ND-H14.
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
What are your temps like under full load man?
I can't afford the NH-D14 its near £70 that well over what I can afford £45 is the absolute max I can go...
I believe that the highest I have seen was around 85 Celsius at full load. I will check when I get home.
Look into the NZXT Havik. It will probably give you cooler temps, and it will be quieter. http://uk.pcpartpicker.com/part/nzxt-cpu-cooler-rchv12001
Sound I will look into it, was going too just get the money together and just build a custom liquid cooling loop but then I found out about a sale so I picked up the 8320 for £100 and now I can't wait to get to grips with it.
Get a Dark Rock. You wouldn't really do much with an 8xxx on an EVO. Or a NH-D14 if possible (think that's it. Which ever one Linus basically fangirled over.).
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
