I've been looking at possibly using different fans on the AIO I'll be using to help with performance and silence. The NB-ELoop fans from BlackNoise have caught my eye. I know that Phobya and Alphacooling had both made their own versions(though none of which are pwm :(). Has anyone had any personal experience with these fans, and if so, which model?
https://linustechtips.com/topic/779025-eloop-fans/
I use the regular noiseblocker black and white B12-PS version, and they are great.
PWM control is extremely good, fan has decent static pressure and airflow while being extremely quiet.
It's not the quietest of fans (depending on which version you get) but the tone is a very low hum thanks to the magnetic levitation bearing and low wind noise from the rotor design. So even though the db isn't super low it is very close to inaudible.
Obviously the price is one of the highest of any fan on the market and isn't for most people, but I personally have tried almost every white fan on the market and this is for sure the best one.
Planning to buy a few of the new 140mm version soon.
https://linustechtips.com/topic/779025-eloop-fans/#findComment-9823831
