I am looking for a ATX case (full or mid) that has a fair amount of space and decent air cooling. I live in the U.S. and am looking for something in the $75 - $100 range. I would also prefer not to have a window on a side I won't be looking at the computer often and I would rather have more fans or performance. I tried to research this myself and came to the conclusion that all the cases I thought about buying were five to seven years old. I am not sure if that is very important but this is my first build and I want to get it right.
Thank you so much for your time!
https://linustechtips.com/topic/778967-first-time-builder-case-suggestions/
Fractal Design Define C
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
Corsair 270R. Perfect beginner case. If you are looking for easy building I would suggest a modular or semi modular power supply. It helps a lot with cable management.
http://www.corsair.com/en-us/carbide-series-270r-atx-mid-tower-case
