I helped someone build a computer and I bought some parts from them for 120$ https://pcpartpicker.com/list/pJWJXH I had a sketch af power supply, cpu cooler someone gave me and an ssd lying around that I added. I want it to be out of my way on a shelf because I don't have a lot of room on the floor near my desk. I would like the case to come with a psu but just recommend me whatever is best for loosely around 100$. I will probably end up buying a psu separately anyway. Thank you for your time.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/778125-atx-htpc-case/
I personally suggest that you at least get quality (doesn't mean expensive) PSU.
As for cases, I don't know if you care too much about looks or want to save mor money, but you could look into used cases that fit your build whether they be htpc or not. You could also look into towers that can be converted into horizontal desktops. HTPC cases have been going up in price, I like some of the Silverstone and fractal design, but they combined with a psu might be out of your budget.
https://linustechtips.com/topic/778125-atx-htpc-case/#findComment-9814025
Silverstone GD09B and a decent yet cheap PSU:
Case: Silverstone - GD09B HTPC Case  ($72.99 @ SuperBiiz)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply  ($44.90 @ Amazon)
Total: $117.89
Generated by PCPartPicker 2017-05-11 11:05 EDT-0400
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/778125-atx-htpc-case/#findComment-9815988
Total: $117.89
Thanks that is what I'm looking for.
https://linustechtips.com/topic/778125-atx-htpc-case/#findComment-9817701
