Help with GTX 780
Go to solution Solved by Meshkis,
So i took my system to shop and asked to test it and turned out that the PCI-E connector on the motherboard was defective they tried 5 different graphics cards in the system and only one of them connected properly.
Hi i just recently bought new system , built it myself everything went well with the exception that when i try to connect my monitor directly from gpu connector my monitor fails to detect signal . Once i try to connect to onboard connector everything works fine ( i also have to remove graphics card completly from the system ) . By now i tried to change cables from DVI-I to VGA ( i think thats how its called) also updated my BIOS and cleared CMOS nothing worked .
My specs
MSI Z87-G43
Intel i5 4670K
Corsair CX750m
MSI GTX 780 Lightning
PS. Sorry for my bad english
https://linustechtips.com/topic/77757-help-with-gtx-780/
I've heard of folks having issues with weak DVI cables, or not having a cable that supports dual link dvi....just throwing something out there
 MOBO: Gigabyte GA-Z77X-UD5H || CPU: Intel Core i7 3570k @4.2GHZ || COOLER: CoolerMaster Hyper 212 Evo || RAM: 16GB GSkill Sniper Gaming Series  || PSU: Corsair HX750 80+ Gold || GPU: Gigabyte GTX 780 Ghz Edition || MONITOR: Asus PB278Q || HDDs: x1 WD 1TB Black x1 WD Black 500GB || SSD: OCZ Agility 3 240gb || KEYBOARD & MOUSE: Corsair K60, Corsair M90 || CASE: Rosewill Thor V2 White
https://linustechtips.com/topic/77757-help-with-gtx-780/#findComment-1069246
