Ok so i have found the necessary parts to build a computer that i would love to get but i want to overclock and the stock fan for the GPU and the CPU aren't good enough to overclock the parts high enough for a significant increase. I was wondering if someone could find a good fan i can use for overclocking my GPU and CPU from http://pccasegear.com/ because i'm in Australia.
GPU- XFX Radeon R9 290 4GB
Memory- G.Skill Sniper F3-14900CL9D-8GBSR 8GB (2x4GB) DDR3
CPU- AMD FX-8320 8 Core Black Edition Processor
MothrerBoard- Gigabyte GA-970A-D3P MotherBoard
Harddrive- Western Digital WD Green 1TB WD10EZRX
Case- BitFenix Shinobi Black Case
Optical Drive- Samsung SH-224DB 24x DVDRW OEM
Power Supply- Corsair GS-700 V2 Power Supply
Total Cost- $1160
https://linustechtips.com/topic/77751-i-need-a-good-fan/
Ummm... Noctua?
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/77751-i-need-a-good-fan/#findComment-1067671
R9 290 is brand new. There are no better coolers for the card at the moment. Cards with better cooling are expected in the next few weeks, but who knows?
Air cooling of the cpu can be done with something like the Hyper 212 EVO which will do a decent job and even allow reasonable overclocking. Better cooling and thus higher potential overclocking on air would need something like the Noctua NH-D14. AIO (All-in-one liquid) coolers that would suit are the Corsair H60 or H80i which would give the best cooling of those mentioned.
I'd recommend that regardless of gpu and cpu cooling you add two 120mm fans to the front intakes of the case.
https://linustechtips.com/topic/77751-i-need-a-good-fan/#findComment-1067754
You won't be oc'ing that much with that mobo. A Hyper 212 Evo would do nicely. As for the gpu, please wait for aftermarket 290's.
The build's a bit awkward to begin with. What's the system being used for? Budget?
https://linustechtips.com/topic/77751-i-need-a-good-fan/#findComment-1067859
Gaming system, budget $1300
But your right i won't be getting this till early 2014 so i can wait for better models of the 290
https://linustechtips.com/topic/77751-i-need-a-good-fan/#findComment-1067879
I suggest you plan later--2-3 days at most before you buy. Parts and prices change frequently. Any build you have now is bound to change several times by then.
https://linustechtips.com/topic/77751-i-need-a-good-fan/#findComment-1067896
I agree with this. I already had a build open however, so lets just post that for lulz..
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($158.97 @ OutletPC)
Motherboard:  Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($114.99 @ NCIX US)
Video Card:  XFX Radeon R9 280X 3GB Video Card (2-Way CrossFire)  ($298.99 @ Amazon)
Case:  BitFenix Shinobi Window ATX Mid Tower Case  ($59.99 @ NCIX US)
Optical Drive:  Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.98 @ OutletPC)
Total: $1297.18
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-11-18 20:59 EST-0500)
EDIT: I forgot that the SuperNova won't work with Gigabyte boards
Motherboard:  Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($104.99 @ Newegg)
Optical Drive:  Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.99 @ Newegg)
Total: $1288.52
(Generated by PCPartPicker 2013-11-19 08:05 EST-0500)
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/77751-i-need-a-good-fan/#findComment-1068038
Total: $1297.18
What this guy is suggesting sounds better go with that
https://linustechtips.com/topic/77751-i-need-a-good-fan/#findComment-1069687
Well, I have Be Quiet! silent wings 2 in my rig, and they work out pretty well, Noctua, corsair and Gentle Typhoons are also good choices.
LOOK AT MY TUBE, MY TUBE IS AMAZING. DONT LICK IT IT DOESN'T TASTE LIKE ANYTHING. IT DOESN'T HAVE A MANE OR PENIS EITHER. SHUT UP.
https://linustechtips.com/topic/77751-i-need-a-good-fan/#findComment-1069821
