Take them all out and try the sticks one by one.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/777386-stuck-at-starting-screen/#findComment-9805046
Just now, Volde said:
I did and this poped up
Try the old RAM and make sure something's not gone wrong with the rest of the system.
Main System: Phobos
https://linustechtips.com/topic/777386-stuck-at-starting-screen/#findComment-9805091
2 minutes ago, Volde said:
I have an option to lauch startup repair and start windows normaly i chose launch repair i got to that screen.
Try with the old RAM. That startup repair thing never works right.
Main System: Phobos
https://linustechtips.com/topic/777386-stuck-at-starting-screen/#findComment-9805126
1 minute ago, Volde said:
Should i put my new ram in in these slots?
Try to put one in the blue slot on the left, marked as A1.
Main System: Phobos
https://linustechtips.com/topic/777386-stuck-at-starting-screen/#findComment-9805153
There is a mem ok button should i press it?
Sorry, but I have no idea what that does.
Main System: Phobos
https://linustechtips.com/topic/777386-stuck-at-starting-screen/#findComment-9805171
Ok when i put in old ram it starts ok when i put in new ram i get that screen
Does the system POST without the HDD (or SSD) connected?
Main System: Phobos
https://linustechtips.com/topic/777386-stuck-at-starting-screen/#findComment-9805182
I dont know they are both connected the ssd and hdd only when i swich ram from old to new the sistem dosent post
Unplug them and try the new RAM.
Main System: Phobos
https://linustechtips.com/topic/777386-stuck-at-starting-screen/#findComment-9805198
I get this i clicked the memok button wich should fix stuff with the memory but it just restarts the computer
Do you have another computer with which you can try that new memory?
Main System: Phobos
https://linustechtips.com/topic/777386-stuck-at-starting-screen/#findComment-9805222
5 minutes ago, Volde said:
No
It could be bad memory, or it's just not compatible with your motherboard.
Main System: Phobos
https://linustechtips.com/topic/777386-stuck-at-starting-screen/#findComment-9805245
