I also noticed that AIDA64 is reporting wrong temperatures for my R7 1700.
HWmonitor, hwinfo and Ryzen master are all reporting same temps (hwmonitor is off by 1°C).
Your Ryzen master temps are the correct ones.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
I believe the ryzen master should be the most accurate.
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
But why?
5 minutes ago, Adarsh Singh said:
But why?
That's a good question for AMD.
Most likely because it's new platform and they are not using same sensors like Intel or previous AMD CPUs.
Just rely on amd master software.
WD My Cloud 4TB
7 hours ago, Adarsh Singh said:
But why?
Beacause it is BUILT for ryzen CPUs.
42
also,
My build:
