the Alienware Area 51 probably comes with a GTX 1080 TI Founders Edition (the 2014 R2 Version of the Area 51 came with a Founders Edition Titan Z,not sure about the 1080 TI edition but probably founders,because if the manufacturer equips the computer with a GPU that they does not make their own edition of the card,they will most likely use founders,but if they make their edition,eg:ASUS uses their cars in their computers,or founders edition,depends)
PC Specs:Custom Built PC
CPU:AMD Ryzen 3 1200 GPU:Zotac GeForce GTX 1050 TI Mini RAM:Corsair Vengence 2400 MHz DDR4 Motherboard:ASUS Prime B350M-A AM4 Motherboard Case:Corsair 100R PSU:Corsair VS450
Laptop Specs:Acer TravelMate 8472
CPU:Intel Core i5 560M Memory:2GB DDR3 CPU:Intel HD Graphics Case:Its a Laptop Motherboard:Laptop Motherboard
https://linustechtips.com/topic/777360-help-plz/#findComment-9804765
19 minutes ago, L.Lawliet said:
Dont buy it.. its overpriced
What like every pre built? It's their money. I'm tired of people saying, "oh that's over priced" you have to figure in custom chassis, labor costs, just manufacturing expenses. Yes you could build a pc with the same parts for less, but you don't get the chassis. People don't work for free all the time.
Corsair 4000D RGB
Asus B550 Tuf Gaming II
Asus 7700XT Tuf Gaming
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/777360-help-plz/#findComment-9804859
