Ryzen upgrade advice
Go to solution Solved by i_build_nanosuits,
this is a good kit that is proven to work well:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($218.55 @ OutletPC)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  ($107.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($119.89 @ OutletPC)
Total: $446.43
Generated by PCPartPicker 2017-05-08 23:00 EDT-0400
All B350 and X370 boards can overclock, which are the overwhelming majority of boards.
A320 boards can't OC, but that's because they are meant for super low-end systems and prebuilt, and usually have something abominable like 2 phases or something, so you wouldn't want to OC on an A320 anyway. All Ryzen CPUs are unlocked, and I'd suggest a 1600 instead of a 1600X, as it comes with a cooler, and is basically the same when both are overclocked. as for a motherboard, the MSI B350 PC Mate seems really nice and cheap.
https://www.msi.com/Motherboard/B350-PC-MATE.html#productFeature-section
https://www.newegg.com/Product/Product.aspx?Item=9SIA1N85KR6942&cm_re=B350_PC_MAte-_-13-144-029-_-Product
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/777280-ryzen-upgrade-advice/#findComment-9803544
don't be fooled by the ''X'' and get the R5 1600 it's the same CPU assuming you'll overclock both of them a bit anyways and as a bonus the R5 1600 comes with a cooler which could be useful down the road if your AIO fail or something...
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/777280-ryzen-upgrade-advice/#findComment-9803569
Total: $446.43
https://linustechtips.com/topic/777280-ryzen-upgrade-advice/#findComment-9803575
im running a Asrock AB350m Pro4 (same as the normal pro4 just mATX) last BIOS update fixed some of the ram speeds, but all in all great board, easy OC to 4Ghz on it, 9power phases (6 on CPU) 2x m.2, really worth a look at, cheap with ALOT of kit to give, would defiantly recommend
https://linustechtips.com/topic/777280-ryzen-upgrade-advice/#findComment-9803653
I'll check it out, thanks,
Quote
https://linustechtips.com/topic/777280-ryzen-upgrade-advice/#findComment-9826928
