Since the prices of the 1080 have gone down I've been looking to buy one. I have found two on amazon both are from Evga and I was wondering if i spend the extra money on a open air since the blower is $439 as of now or if i should spend $530 on the SC2/SC. Which would you recommend I have a Define r5 case so they would both cool pretty well in my case.
open air: https://www.amazon.com/EVGA-GeForce-Support-Graphics-08G-P4-6286-KR/dp/B01K1JW8CW/ref=sr_1_1?s=pc&ie=UTF8&qid=1494295345&sr=1-1&keywords=Evga%2B1080&th=1
Blower: https://www.amazon.com/EVGA-GeForce-Support-Graphics-08G-P4-6286-KR/dp/B01K1JW8CW/ref=sr_1_1?s=pc&ie=UTF8&qid=1494295345&sr=1-1&keywords=Evga%2B1080&th=1
https://linustechtips.com/topic/777271-open-air-or-blower/
really depends on your case.
If its mITX depending on the case then blower is better*. If its a full ATX or a mid tower open air should be fine.
For me my mITX system is water cooled and the GPU idles at 60C (open air) while the CPU floats at around 35 on water which hard to complain about.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/777271-open-air-or-blower/#findComment-9803376
From personal experience of running an open-aire gigabyte gtx 1060 in my define r5 - openair will be fine in your case
im running my define r5 with
2x140 intake at the front
1x120 intake at the bottom
removed my top HDD case
1x140 exhaust at the back
my GTX 1060 doesnt go over 62c
I say get the open-air EVGA card, its usually overbuilt and allows your gpu to run cooler and quieter - also alllows for a better GPU boost to clock speeds
Photography / Finance / Gaming
https://linustechtips.com/topic/777271-open-air-or-blower/#findComment-9803431
Define R5 is an ATX mid-tower, so go with the open-air design.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/777271-open-air-or-blower/#findComment-9803432
29 minutes ago, PyroDaddy said:
Thank you for the replies, I was also wondering if I should save up a little and get a 1080ti or if I should stick with getting the 1080?
Really depends imo. For 1080p a 1080 will be plenty of power for a long time.
if you plan to game at 1440p or even 4K a 1080ti will give you a better experience.
Also if you spent as much money on a gpu like the 1080 you might as well go for the ti as it has around 20-25% more performance.
https://linustechtips.com/topic/777271-open-air-or-blower/#findComment-9806980
It's also like 50% more expensive
https://linustechtips.com/topic/777271-open-air-or-blower/#findComment-9807118
