Internal USB: 11-pin plug on 9-pin connector?
Solved by Mira Yurizaki,
Supposedly you can leave the extra two pins dangling: https://forums.lenovo.com/t5/ThinkStation-Workstations/Proprietary-USB-header-on-D10-6493/td-p/748699
However, the wiring has me concerned. Standard USB coloring for wires state that red is +5V and where that red wire is going is not where it's supposed to go on a standard USB front panel header.
Featured Topics
remo233 ·
1
6
10
rickymohk ·
Posted in General Discussion2 -
Rbakker02 ·
Posted in General Discussion1 -
BaidDSB ·
Posted in General Discussion5 -
2
Mistr J ·
Posted in Troubleshooting3 -
2
