2 minutes ago, Hoseiny said:
Should i pick 1600x or 7600k for gaming only as i see ryzen run smoother and win i some titles
With 1070 or rx 580
I am not going to overclocking.
Sorry for bad english
If you're not overclocking don't go with the 7600k or the 1600x
Rather get a 7500 or a 1600.
If you take these two I would take the 1600 over the 7500, because at full hd or 4k it's not that of a huge difference between them and the 1600 has more multicore performance if needed.
https://linustechtips.com/topic/776777-help-in-new-build/#findComment-9797177
You can still overclock the 1600..
With 1070 or rx 580
Go for the 1600x
https://linustechtips.com/topic/776777-help-in-new-build/#findComment-9797185
1070 is more powerful than the 580. 1600 or 1600X will be fine. 1600X will need an aftermarket cooler. Cryorig H7 is what I would recommend.
Delta R5 Build
CPU: AMD RYZEN 1600 Purchased
Motherboard: ASUS PRIME B350-PLUS  Purchased
RAM: Corsair Vengeance 16GB DDR4 3000MHX (2X8GB) Purchased
CPU COOLER: DeepCool GAMMAXX 400 GT RGB Purchased
GPU: Gigabyte Xtreme Aorus 6gb GTX 1060 Purchased
Case: NZXT S340 (White) Purchased
PSU: EVGA 550B3 Purchased
HDD: WD Blue 1TB  Purchased
SSD: Sandisk SSD PLUS 120GB Purchased
Wifi Card: Asus PCE-N15 PCI-E 1X Purchased
--BUILD READY--
https://linustechtips.com/topic/776777-help-in-new-build/#findComment-9797200
6 hours ago, Hoseiny said:
for gaming only
IMO, get i5 7500 for 1080p/1440p gaming or Ryzen 5 1400/1600 for 4K gaming
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/776777-help-in-new-build/#findComment-9798543
