Hey guys, i just got a new GTX 1070 Super Jetstream from Palit.
The standard clock is 1632mhz and the boost clock should be 1835mhz.
But when im playing something it goes up to 1949mhz.. (Without any overclock!)
Is this normal? and is this healthy?
The Card just got one 8 pin power connector.
https://linustechtips.com/topic/776577-boost-clock-too-high/
This is a feature of the new GPU Boost 3.0 IIRC. It boosts the card as high as thermals or power will allow at a given moment, hence you can achieve higher clock than the advertised boost clock.
[Edit] Yes it's safe, don't worry the card boosts that high because circumstances allow it ;)
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/776577-boost-clock-too-high/#findComment-9794747
The standart clock is 1632mhz and the boost clock should be 1835mhz.
yes this is normal, this is called gpu boost 3.0 most cards clock beyond advertised clock speeds.
if your temps are low the card will boost higher basically
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/776577-boost-clock-too-high/#findComment-9794754
7 minutes ago, Icefly said:
Okay.. that means i should underclock my card to disable it or is there a official way to disable gpu boost?
There is no way. Why would you want to disable it? It just gives you more performance for free?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/776577-boost-clock-too-high/#findComment-9794806
My guess is that the advertised boost clock is the one they are sure the card will reach and can sustain. If it would be unsafe (e.g. high temperatures) to go higher it will not go higher or clock back to the advertised speed. There's no need to worry and no need to underclock. Like @DocSwag said you get free performance.
https://linustechtips.com/topic/776577-boost-clock-too-high/#findComment-9795052
27 minutes ago, Icefly said:
Still scary...
I want a pc that lives as long as possible. As far as i know it's not good for the lifespan of my pc.
That's why i don't want all that fancy overclock stuff.
I would like to see my pc living for 5 years.
Thx for all the answers! ^^
Clock speeds don't damage silicon, heat (and very high voltage) does. As long as your temps are in check you should have no problems.
LTT Unigine SUPERPOSITION scoreboardhttps://docs.google.com/spreadsheets/d/1jvq_--P35FbqY8Iv_jn3YZ_7iP1I_hR0_vk7DjKsZgI/edit#gid=0
Intel i7 8700k || ASUS Z370-I ITX || AMD Radeon VII || 16GB 4266mhz DDR4 || Silverstone 800W SFX-L || 512GB 950 PRO M.2 + 3.5TB of storage SSD's
SCHIIT Lyr 3 Multibit || HiFiMAN HE-1000 V2 || MrSpeakers Ether C
https://linustechtips.com/topic/776577-boost-clock-too-high/#findComment-9801197
Some basics about overclocking: components die not because of high clock speeds, but because of high temperature.
So, as long as the temp stays below 80C, it should last forever lol
Why would you not want free frames per second? it makes it smoother
CPU: Ryzen 2 2700@ 4.0Ghz    Mobo: Gigabyte X470 Gaming 7 Wifi    Cooler: EVGA CLC 240    GPU: GTX1080 FTW DT @ 2113Mhz   PSU: EVGA 750W P2
Case: Fractal Design Meshify C   Displays: 34" LG34UC79G, 24" Dell
https://linustechtips.com/topic/776577-boost-clock-too-high/#findComment-9801406
NO, it means you should not worry about a good FEATURE, and just enjoy the Card ;)
Even if you Overclock your card to 2 Ghz or more, you will most likely upgrade your GPU because it's too slow in 3-5 years, than the GPU dying.
it's not like your GPU will explode just because of a few Mhz more. Overclocking does much less impact on lifespan, than most people think :)
https://linustechtips.com/topic/776577-boost-clock-too-high/#findComment-9801796
5 hours ago, Icefly said:
Still scary...
even overclocked (which it is NOT: gpu boost is normal), the card should last a lifetime (or at least last until it becomes obsolete). ofc hardcore overclocks are different, but the common "user overclock" wont cause perceivable lifespan degradation.
And just ignore the speeds advertised, in the 1000 series they mean nothing. Almost every 1070 can achieve 2000MHz.
Ultra is stupid. ALWAYS.
https://linustechtips.com/topic/776577-boost-clock-too-high/#findComment-9802617
