dont get the 1600x and get the 1600 non x since oc'd 1600 performs same as 1600x
and just get whatever is cheaper between these two with the motherboard and cooling total cost, they perform the same
the 7700 wont give you any thermal problems, the one is the 7700k and also, you should not oc a locked cpu, get unlocked one
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9794482
but news said both of them 7700k and non k
exceed 90c
https://www.techpowerup.com/233018/temperature-spikes-reported-on-intels-core-i7-7700-i7-7700k-processors
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9794506
2 hours ago, Hoseiny said:
but some people told me that 7700 is better for pure gaming pc
rather than picking 1600x
and other said it's future proof for dx 12
sorry for bad english
Personally I'll go for 7700 non K if you ONLY do gaming
2 hours ago, deXxterlab97 said:
what game?
Wow you're back...
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9794513
that depends on your gpu, not cpu (remember to quote please)
and since both performs the same at stock speeds, if you get ryzen, you will be able to overclock and get more fps
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9794518
thanks but as i said i am not planning to over clock
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9794524
well, the 1500x performs equal to 7700...
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9794526
then dont xD
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9794532
7 minutes ago, Hoseiny said:
so 1600x is good after optimiztion for gaming companies about one year from now i am right or wrong
it was supposed to be for budget content creator people, but seems that even performs better than the i7 7700 on everything for less money and overclockable
Edited by Blackhole890
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9794573
Source?
Desktop specs:
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9794591
1 hour ago, Blackhole890 said:
Ryzen 5 CPUs can't beat 6600K/7600K/6700K/7700/7700K in gaming performance. Remember that.
Desktop specs:
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9794830
Does i7 7700(non k)
Have temperature problem ?
Because i don't know what processor to go with 1600x ot 7700(non k)
what is your budget for rig
My Rig : https://pcpartpicker.com/list/MTBd2R
My VM Server : https://pcpartpicker.com/list/rPR6gL
My Backup Server : https://pcpartpicker.com/list/cRQYYr
My Storage Server : https://pcpartpicker.com/list/tzzR9W
My Router : https://pcpartpicker.com/list/bMPN4C
My Laptop : Lenovo Z575 with 6 GB RAM (1866 MHz), Crucial MX300 525 GB & Western Digital 2 TB (Removed optical drive)
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9795078
Just want to know which best for pure gaming only
7 minutes ago, Dutch-stoner said:
Depends on CPU cooler and case. But it doesn't have to have temp problems.
However, just go with Ryzen.
Why ryzen?
Can you tell me difference bt both.
https://linustechtips.com/topic/776550-help-in-new-build/#findComment-9795093
